Software Archive
Read-only legacy content
17060 Discussions
Intel XDK Update not allowing old projects to open
Evan_H_
Helloo all. I recently upgraded to version 2496 of the XDK. Ever since then, i cant open any of my old projects. I need to open them now to edit them because one of my apps on the market has a bug in it. Anyways, why is this? It asked me to remove them from the list, and i did, but oit wont let me open any new ones. Can i downgrade or what? Thanks!
Amrita_C_Intel
Can you try now?
PaulF_IntelCorp
Can you provide more details regarding the problem? What do you mean by "cannot open any of my old projects"? Not clear why it asked you to remove them from the list.
If you want to open an existing project that is not on the list in the Projects tab:
  • goto the Projects tab
  • select the green button at the bottom left (Open an Intel XDK Project)
  • navigate to the directory that contains the project you want to open
  • select the <project-name>.xdk file in that directory
If your project needs to be upgraded, you need to select the "Upgrade" button in order to upgrade that project (use your mouse, do not hit the "Enter" key). If you select "Cancel" and then select "Remove Project" your project will be removed from the Projects tab list.
