Software Archive
Read-only legacy content
17060 Discussions
the question about backbutton event
Wang_Y_2
i register the backbutton listener in index page ,it works when i press the back button.but in the second level page,there is no response
for example:
index.js:
document.addEventListener("deviceready", onDeviceReady, false);
    // Cordova is loaded and it is now safe to call Cordova methods
 function onDeviceReady() {
        //alert(999);
        // Register the event listener
        document.addEventListener("backbutton", onBackKeyDown, false);
index.html:
<script type="text/javascript" charset="utf-8" src="cordova.js"></script>
<script src="js/index.js"></script>
Dale_S_Intel
Are you testing this in the Emulator, or with App Preview or Debug?
Dale
Dale_S_Intel
I'm seeing the same issue.  It looks like it's not working in Cordova 5.1.1 but is working in 4.1.2.  If it works for you to change Cordova versions I would recommend that until there is a fix.  To do that go to your projects page, expand "Build settings" then look for "Cordova CLI Version".  Click on that circle just to the right of the version number and you should see a drop-down menu with two choices, just switch that to 4.1.2 and see if that works for you.  Note, if you're using some third party plugins you may need to make sure they're the appropriate version to work with that Cordova version, as a lot changed between 4 and 5.
Meanwhile I'll do what I can to try to get a fix for Cordova 5.  I'll update here when I have more info.
Dale
Wang_Y_2
I testing this with android phone
