Software Archive
Read-only legacy content
17060 Discussions
Intel XDK build failed, but BUILD SUCCESSFUL in log.
Pavel_I_
I have an application which I a build quite often, several times a month, it worked before, but when I tried Today it did not work.
Build log: http://pastie.org/private/vruam6di1caneki7bkssw
Intel XDK screenshot: http://prntscr.com/a4yq8n
P.S. I use quite an old version of Cordova 3.5.1
P.S. I tried another project which I created recently with latest everything, it created the APK successfully.
Pavel Iacovlev
Elroy_A_Intel
We no longer support the building of projects using Cordova 3.5.1. You will receive failure due to plugin incompatibility and deprecation of prior Cordova version support below 4.1.
