Software Archive
Read-only legacy content
17060 Discussions
Intel XDK hang up on start behind a proxy with authentication
tetsuya
I've been using Intel XDK and I love it.
Today, my colleague tried to use Intel XDK but it hanged up on start up dialog telling "Initializing...".
After several trial-and-errors, I found it occurs when we start the software under the proxy of our company which requires authentication by user and password.
When I use some bypass tool, it succeeds to start, but this workaround cannot be widely revealed because it may violate the company's policy.
Is there anything I can do?
tetsuya
PaulF_IntelCorp
Does the technique described here help? > https://software.intel.com/en-us/xdk/faqs/general#bad-proxy
We're working on providing some better diagnostics regarding this problem, so you won't have to waste time in the future chasing down this problem.
Elroy_A_Intel
If you are running a Windows machine, I recommend configuring your proxy settings via the Control Panel > Network and Internet > Internet Options. There is an Intel XDK FAQs page at https://software.intel.com/en-us/xdk/faqs/general.
tetsuya
Thank you Paul and Elroy.
Sorry of insufficient information.
We are using Intel XDK on Windows and proxy settings is fine in usual cases (ex. through a browser).
Intel XDK hang up when I use the proxy which requires authentication.
If I use a bypass program which provides user/password for the actual company proxy, the proxy settings XDK looks at does not require authentication and it succeeds to start.
I guess XDK does not handle 407 error (proxy authentication required), does it?
tetsuya
