Software Archive
Read-only legacy content
17060 Discussions
Intel Xeon Phi - MPI application
H__Kamil
I created simple "Hello world" apllication. I tried to run program, as show in this article:
https://software.intel.com/en-us/articles/using-xeon-phi-prefixes-and-extensions-for-intel-mpi-jobs-in-nfs-shared-environment
But in result I got following error:
# bash: /opt/intel//impi/5.0.3.048/intel64/bin/pmi_proxy: cannot execute binary file
I use system with HOME directory shared between host and card.
What Is the problem? Thanks for help.
Artem_R_Intel1
Hi Kamil,
Have you performed this export before the run?
$ export I_MPI_MIC=enable
H__Kamil
I forgot about it. After setting the variable another error.
[proxy:0:1@miclab-01-mic0.localdomain] HYDU_sock_connect (../../utils/sock/sock.c:268): unable to connect from "miclab-01-mic0.localdomain" to "10.0.1.1" (No route to host)
[proxy:0:1@miclab-01-mic0.localdomain] main (../../pm/pmiserv/pmip.c:403): unable to connect to server 10.0.1.1 at port 41337 (check for firewalls!)
What about it?
Sunny_G_Intel
Hello Kamil,
Please refer to the following similar forum question: https://software.intel.com/en-us/forums/topic/542161#comment-1815235
Thank you
