Software Archive
Read-only legacy content
17061 Discussions
Intel Xeon Phi not found using examples but micinfo works
vincent_b_
I compiled the Sample00c example present in the composer_xe_2013.5.192 directory and I ran it.
This is the output :
Checking for Intel(R) Xeon Phi(TM) (Target CPU) devices...
Number of Target devices installed: 0
Offload sections will execute on: Host CPU (fallback mode)
However, if I do a "lspci | grep o-pro" I get :
29:04:00.0 Co-processor: Intel Corporation Device 225d (rev 11)
94:83:00.0 Co-processor: Intel Corporation Device 225d (rev 11)
And if I run /opt/intel/mic/bin/micinfo :
MicInfo Utility Log
Created Fri Jul 11 18:39:34 2014
        System Info
                HOST OS                 : Linux
                OS Version              : 2.6.32-279.5.2.bl6.Bull.33.x86_64
                Driver Version          : 6720-16
                MPSS Version            : 2.1.6720-16
                Host Physical Memory    : 65950 MB
Device No: 0, Device Name: mic0
        Version
                Flash Version            : 2.1.03.0386
                SMC Firmware Version     : 1.15.4830
                SMC Boot Loader Version  : 1.8.4326
                uOS Version              : 2.6.38.8-g2593b11
                Device Serial Number     : ADKC24200744
        Board
                Vendor ID                : 0x8086
                Device ID                : 0x225d
                Subsystem ID             : 0x2500
                Coprocessor Stepping ID  : 3
                PCIe Width               : Insufficient Privileges
                PCIe Speed               : Insufficient Privileges
                PCIe Max payload size    : Insufficient Privileges
                PCIe Max read req size   : Insufficient Privileges
                Coprocessor Model        : 0x01
                Coprocessor Model Ext    : 0x00
                Coprocessor Type         : 0x00
                Coprocessor Family       : 0x0b
                Coprocessor Family Ext   : 0x00
                Coprocessor Stepping     : B1
                Board SKU                : B1PRQ-3115A
                ECC Mode                 : Enabled
                SMC HW Revision          : Product 300W Active CS
        Cores
                Total No of Active Cores : 57
                Voltage                  : 1054000 uV
                Frequency                : 1100000 kHz
        Thermal
                Fan Speed Control        : On
                Fan RPM                  : 2700
                Fan PWM                  : 50
                Die Temp                 : 62 C
        GDDR
                GDDR Vendor              : Hynix
                GDDR Version             : 0x3
                GDDR Density             : 2048 Mb
                GDDR Size                : 5952 MB
                GDDR Technology          : GDDR5
                GDDR Speed               : 5.000000 GT/s
                GDDR Frequency           : 2500000 kHz
                GDDR Voltage             : 1501000 uV
Device No: 1, Device Name: mic1
        Version
                Device Serial Number     : ADKC24200611
        Board
                Vendor ID                : 0x8086
                Device ID                : 0x225d
                ECC Mode                 : Enabled
        Cores
                Voltage                  : 999000 uV
        Thermal
                Fan RPM                  : 2700
                Fan PWM                  : 51
                Die Temp                 : 81 C
        GDDR
                GDDR Vendor              : Hynix
                GDDR Version             : 0x3
                GDDR Size                : 5952 MB
I also tried many other simple offload codes.
But nothing runs on the xeon phi.
Could you please point me out what is the problem ?
Thank you !
Vinczo
Kevin_D_Intel
In past instances of similar reports I found the user's environment was not initialized correctly as per compilervars.sh/csh setup scripts.
You can refer to additional details in the earlier post here and then double check that you source'd the compilervars.sh/csh script and that the LD_LIBRARY_PATH variable is setup correctly as discussed in the earlier cited post.
vincent_b_
Thanks Kevin,
That worked!
I was using modules to load environment but it appeared that not all variables were loaded by the module...
Best regards!
Kevin_D_Intel
Excellent!  Glad to hear that helped.
