where can I download Intel C++ and Fortran compilers (version 11.0.069) for non-business?
Log on to the intel registration center https://registrationcenter.intel.com/RegCenter/Register.aspx and you should be able to download it.
If you haven' registered your license, goto the same place to register and download.
Jennifer
Jennifer
Quoting - Jennifer Jiang (Intel)
Jennifer
Jennifer
Thank you for your help, Jennifer.
I log on to the registration center and I could download the compiler. But its version is 11.1.056 instead of 11.0.069. Any idea about how to download the version 11.0.069?
There's a version number selector on that site which you can set back to earlier versions.
Quoting - tim18
I remember there's a version selector before. But where is it now? I can't find it.
Greetings,
I just resend you the license file. In that e-mail, there is a download link , similar to this https://registrationcenter.intel.com/RegCenter/MySerialNumbers.aspx?sn=xxxx-xxxxxxxx&[email protected]&Sequence=xxxxxx
Click on that link, you will see a subsciprtion history page with links to download files. Click on download files link. You will be provided with a new page and at the bottom of this page there is a drop down to download required versions and builds.
//I have attached screen shot here.
Shamla
Quoting - Shamla (Intel)
Greetings,
Shamla
Thanks so much, Shamla. This is exactly what I want.
I had the same problem when I download IPP and MPI packages:
- I want IPP 6.0.0.063 (em64t) for non-business, but I can download IPP 6.1.1.042 only.
- I want MPI 3.2.1.009 to evaluate, but I can download MPI 3.2.2.006 only.
Thanks again.
Quoting - white888
Thanks again.
I have send you the license file for IPP and it has the link for the download, click on the link, then the download files and choose the version from the drop down. In here, you need to choose Package for Intel 64, you will arrive at http://registrationcenter-download.intel.com/akdlm/irc_nas/1243/l_ipp_em64t_p_6.0.0.063.tar.gz
I don't see any active registrations for MPI.
Thank You
Shamla
Got it. Thanks so much.
Thank you for the update.
Shamla
Shamla
