I have a HP G70-111EM laptop, the screen size is 17" and uses 1440x900 resolution. I broke the screen so decided to use my moniter on it which is a 19" and also uses the 1440x900 resoulution. The problem is I can't get the resolution set to 1440x900 for the monitor. I've tried the driver ect what intel have provided but it doesn't work.
The moninfo program gives out
Monitor
Windows description...... Generic PnP Monitor
Manufacturer............. LG-Philips
Plug and Play ID......... LPLA104
Data string.............. LGPhilipsLCD LP171WP4-TLN2
Serial number............ n/a
Manufacture date......... 2007, ISO week 0
EDID revision............ 1.2
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 370 x 230 mm (17.2 in)
Power management......... Not supported
Extension blocs.......... None
DDC/CI................... n/a
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.602 - Ry 0.349
Green chromaticity....... Gx 0.323 - Gy 0.551
Blue chromaticity........ Bx 0.158 - By 0.141
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Range limits............. Not available
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1440x900p at 60Hz (16:10)
Modeline............... "1440x900" 96.210 1440 1504 1536 1760 900 901 904 912 -hsync -vsync
Standard timings supported
Report information
Date generated........... 29/10/2009
Software revision........ 2.41.0.818
Operating system......... 6.0.6002.2.Service Pack 2
Raw data
00,FF,FF,FF,FF,FF,FF,00,32,0C,04,A1,00,00,00,00,00,11,01,02,80,25,17,78,0A,1C,85,9A,59,52,8D,28,
24,50,54,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,95,25,A0,40,51,84,0C,30,40,20,
13,00,6F,E6,10,00,00,19,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,FE,00,4C,
47,50,68,69,6C,69,70,73,4C,43,44,0A,00,00,00,FE,00,4C,50,31,37,31,57,50,34,2D,54,4C,4E,32,00,20
It also says its a philips monitor, but its an ASUS VW192S
The graphics chipset i have is a Mobile Intel 4 Series Express Chipset Family
Can somebody help me get it right?
Monitor
Report information
Raw data
![](/skins/images/71A9511A625CE5D5D45FB59952A4AA71/responsive_peak/images/icon_anonymous_message.png)
