Software Archive
Read-only legacy content
Intel motherboard Video RAM issue
Joshua_B_
I have the Intel DZ77GAL-70K motherboard with BIOS revision 0064. I have been trying to get SecureBoot to work with this motherboard for a while and I haven't had any luck until I set the BIOS settings back to default. After setting them to default I changed the settings one after the other until I discovered that the problem was the video memory being set to 1GB. I changed it to 512MB and I was able to boot into windows with SecureBoot enabled. I remembered two or three BIOS revision back I had this same issue when I first got the motherboard and installed windows 8(without SecureBoot). But then that issue went away after updating to BIOS revision 0064 and I was able to set my onboard video card to 1GB.
Harold_G_Intel
Hi Joshua,
For support on our motherboards you may want to post to our communities here: https://communities.intel.com/community/tech/desktop
We recommend you register an account with Intel communities so you can post your issues and actively participate with the experts and your peers.
Or, you can create a support ticket for this here: http://www.intel.com/p/en_US/support/contactsupport
Regards, Hal
Intel(R) Developer Zone Support
http://software.intel.com
*Other names and brands may be claimed as the property of others.
