I have the following problem : after the installation of the camera I received the following remark (attached screenshot : camera_installation_problem).
We have all minimum requirements, I attached the system information file about my computer : System_information_file_english_version_forum.txt
The depth camera have been working only three times since we installed (i.e. during two weeks) (attached screenshots : device_worked_once_DEPTH; camera_worked_once_IR ). When I tried more times, when I tried to restart computer, when I tried each day during two weeks many many times, it does not work.
All time (except three times) I received the following problem (attached screenshot: device_does_not_work)
I contacted Intel support by this link : https://servicerequestmgmt.intel.com/
We had a long discussion and then they suggested to postulate here my problem.
Also they said that I should contact your Developers from this link : https://software.intel.com/en-us/intel-realsense-sdk-support
However, after log in, I want to submit the ticket and I can't select the product. When I try "search", it does not work also(attached screenshot : advanced_intel_support).
Thanks if you can help.
链接已复制
It looks like the DCM did not detect the F200 camera. If you got error code -3, you can try following steps.
1, Make sure your camera was connected to USB 3.0, you can try different USB 3.0 port
2, restarted the DCM service after you re-plugin the camera. You can run task manager and click "services" and restart the RealSenseDCM service.
3, Close the application and re-run the application again.
Please let me know if you still have such issue.
Thanks!
Thanks, I tried what you said.
I obtained one depth image, then I retried your suggestions, it was not work. I retried your suggestions 10 times. It was worked and I could obtain also only one image(after it stops to work as usual error : -3). Then I retried your suggestions 10 times and so on.
Conclusion : it works one time in 10 tries and it is possible to obtain only one capture.
Could you give some suggestions, please.
