Software Archive
Read-only legacy content
17061 Discussions
Is cilk slower on Linux than on Windows?
EAnde4
Currently, I am getting decent results with Intel 15 Cilk on Windows. However, the results is not nearly as good on Linux. My feeling is the overhead of a spawn is bigger on Linux. Any suggestions/comments?
I had expected the opposite results i.e. better results on Linux.
I am using fairly new hardware and have tried to disable hyperthreading. Disabling hypertreading improves the result a bit but not much.
TimP
I don't see a consistent relationship between linux and Windows performance of cilk_for, on a Nehalem style CPU with HT disabled.  There are more cases where linux is faster, but a few where Windows is slightly faster consistently.  On a multiple CPU platform, if it happened that one OS was more consistent about preferring the same CPU, I would not be surprised to see a difference.
EAnde4
It turns that a large part problems is caused by some locks/mutexes that cause the issue. For some reason the penalty with locks on Windows is small whereas on Linux the locks kills the performance.
I first got Vtune up and running on Linux today and it helped me pinpoint the problem.
