Software Archive
Read-only legacy content
17060 Discussions
Is fglrendermode a function or subroutine?
Intel_C_Intel
Hi
I am trying to use fglrendermode option. The Opengl book says its a function and the help library says its a function, but the compiler wants it declared as a subroutine. As a function it is supposed to return the number of mouse hits. I am confused as to how this option is to be used. Can someone help me?
Kausik
nijhuis
fglrendermode is indeed a function but the interface in module Dfopngl is not correct.
I solved it by making a separate module with a function ownfglrendermode in which the interface is stated in the right way.
It looks as follows:
integer*4 function ownfglRenderMode  (mode )
!DEC$IF DEFINED(_X86_)
!DEC$ ATTRIBUTES STDCALL, ALIAS : '_glRenderMode@4' :: fglRenderMode
!DEC$ELSE
!DEC$ ATTRIBUTES STDCALL, ALIAS :  'glRenderMode'   :: fglRenderMode
!DEC$ENDIF
integer*4 mode
  ownfglRenderMode = fglRenderMode(mode)
end function ownfglRenderMode
I hope this will help you.
Guus Nijhuis
nijhuis
Sorry for the mess in the first line of the example in the prior message.
Every "!" should start a new line, but I don't know how to get it right.
Guus
I'll fix it - the best way to show code is to bracket it in
I agree that the declaration in DFOPNGL is wrong. We'll fix DFOPNGL in a future update.
Steve
Intel_C_Intel
Hi
I pasted your fix into dfopngl.f90 and then ran my project by invoking
hits=ownfglrendermode(GL_RENDER)
(where hits is an integer)
But I still get the linker error. Am I missing something?
Kausik
What is the linker error?
If you are not also using DFOPNGL, you'll want to add opengl32.lib, glaux.lib and glu32.lib to the list of libraries you link against.
Steve
Intel_C_Intel
Hi
I pasted the fix in Dfopngl.f90 just beneath the interface for "fglrendermode" and I ran my project by invoking "ownfglrendermode". But I get the following linker error:
Linking...
xtalmouse.obj : error LNK2001: unresolved external symbol _OWNFGLRENDERMODE@4
Debug/xtaldraw_w.exe : fatal error LNK1120: 1 unresolved externals
Error executing link.exe.
Should I make any changes to "dfopngl.mod" or any others in addition to modifying dfopngl.f90?
Kausik
Don't paste the code in DFOPNGL.F90 - that won't do a thing for you. Put it in your own code, in the routine that calls fglRenderMode.
Steve
Intel_C_Intel
Hi
When I paste the following code in my routine:
interface
!DEC$ELSE
!DEC$ENDIF
integer*4 mode
end interface
I get a compiler error :
Error: This statement is invalid in an INTERFACE block.
Can someone help me ?
Kausik
Oh, I see. I didn't look at Guus' suggestion closely enough.
Use this instead:
interface
!DEC$ ATTRIBUTES STDCALL, ALIAS : '_glRenderMode@4' :: ownfglRenderMode
!DEC$ELSE
!DEC$ ATTRIBUTES STDCALL, ALIAS :  'glRenderMode'   :: ownfglRenderMode
!DEC$ENDIF
integer*4 mode
end interface
Steve
