Software Archive
Read-only legacy content
17060 Discussions
Is this a bug for icc
Wei_Pan
The following program causes a runtime crash reducer_impl.cpp:527: cilk assertion failed: h
My compiler is icc 13.1.1 on Ubuntu 12.04.
[cpp]
#include <cilk/reducer.h>
#include <cilk/reducer_opadd.h>
#include <cilk/cilk.h>
#include void empty() {}
std::atomic n;
int test(int *x) {
  cilk::reducer_opadd r;
  n = 40000;
  while (n--) {
    cilk_spawn empty();
  return 0;
int main() {
  int x = 1;
  return test(&x);
[/cpp]
Wei_Pan
There are some missing pieces due to the formating
std::atomic should be std::atmoic<unsigned>
and
cilk::reducer_opadd should be cilk::reducer_opadd<unsigned>
ARCH_R_Intel
Thanks for reporting this bug.  I was able to reproduce the problem even without using an atomic variable (see below)   I'll forward it to the right folk.
- Arch
[cpp]
void empty() {}
int main() {
  cilk::reducer_opadd<unsigned> r;
  int n = 40000;
  while (n--) {
    cilk_spawn empty();
  return 0;
[/cpp]
ARCH_R_Intel
A work-around for now is to insert a cilk_sync right before the destructor for r runs.
Wei_Pan
Thanks! I was not sure if there is a limit on the number of spawns and confirms this is a bug or not.
