- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
We have a SLES11 SP3 non original kernel, and mellanox ofed 2.2 and when trying to rebuild the ofed-driver-3.3-1.src.rpm it fails with the following error:
# rpmbuild --rebuild --define MOFED=1 src/ofed-driver*.src.rpm [...] In file included from /usr/src/linux-3.0.101-0.35/include/linux/netdevice.h:34, from /usr/src/linux-3.0.101-0.35/include/linux/if_arp.h:26, from /usr/src/packages/BUILD/ofed-driver/ofa_kernel-1.5.4.1/drivers/infiniband/hw/scif/ibscif_driver.h:39, from /usr/src/packages/BUILD/ofed-driver/ofa_kernel-1.5.4.1/drivers/infiniband/hw/scif/ibscif_main.c:31: /usr/src/ofa_kernel/default/include/linux/pm_qos_params.h:27: error: ‘LINUX_BACKPORT’ declared as function returning a function /usr/src/ofa_kernel/default/include/linux/pm_qos_params.h:27: warning: parameter names (without types) in function declaration /usr/src/ofa_kernel/default/include/linux/pm_qos_params.h:29: error: ‘LINUX_BACKPORT’ declared as function returning a function /usr/src/ofa_kernel/default/include/linux/pm_qos_params.h:29: warning: parameter names (without types) in function declaration /usr/src/ofa_kernel/default/include/linux/pm_qos_params.h:31: error: ‘LINUX_BACKPORT’ declared as function returning a function /usr/src/ofa_kernel/default/include/linux/pm_qos_params.h:31: warning: parameter names (without types) in function declaration /usr/src/ofa_kernel/default/include/linux/pm_qos_params.h:34: error: ‘LINUX_BACKPORT’ declared as function returning a function /usr/src/ofa_kernel/default/include/linux/pm_qos_params.h:34: warning: parameter names (without types) in function declaration /usr/src/ofa_kernel/default/include/linux/pm_qos_params.h:37: error: ‘LINUX_BACKPORT’ declared as function returning a function /usr/src/ofa_kernel/default/include/linux/pm_qos_params.h:37: warning: parameter names (without types) in function declaration /usr/src/ofa_kernel/default/include/linux/pm_qos_params.h:39: error: ‘LINUX_BACKPORT’ declared as function returning a function /usr/src/ofa_kernel/default/include/linux/pm_qos_params.h:39: warning: parameter names (without types) in function declaration In file included from /usr/src/linux-3.0.101-0.35/include/linux/if_arp.h:26, from /usr/src/packages/BUILD/ofed-driver/ofa_kernel-1.5.4.1/drivers/infiniband/hw/scif/ibscif_driver.h:39, from /usr/src/packages/BUILD/ofed-driver/ofa_kernel-1.5.4.1/drivers/infiniband/hw/scif/ibscif_main.c:31: /usr/src/linux-3.0.101-0.35/include/linux/netdevice.h:1064: error: field ‘pm_qos_req’ has incomplete type make[5]: *** [/usr/src/packages/BUILD/ofed-driver/ofa_kernel-1.5.4.1/drivers/infiniband/hw/scif/ibscif_main.o] Error 1 make[4]: *** [/usr/src/packages/BUILD/ofed-driver/ofa_kernel-1.5.4.1/drivers/infiniband/hw/scif] Error 2 make[3]: *** [_module_/usr/src/packages/BUILD/ofed-driver/ofa_kernel-1.5.4.1] Error 2 make[2]: *** [sub-make] Error 2 make[1]: *** [all] Error 2 make[1]: Leaving directory `/usr/src/linux-3.0.101-0.35-obj/x86_64/default' make: *** [kernel] Error 2 error: Bad exit status from /var/tmp/rpm-tmp.44285 (%build)
Dapl and libscif rebuilding went ok. Any ideas?
Thanks in advance
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
We solved it, it was a matter of disorder in the includes. This is how you can solve it, in case anyone else is using SLES11 SP3:
--- ofed-driver/src/kernel/drivers/infiniband/ibp/kmtest/tcp_utils.h.orig 2014-07-25 08:25:24.090751000 +0200 +++ ofed-driver/src/kernel/drivers/infiniband/ibp/kmtest/tcp_utils.h 2014-07-24 15:40:52.001716000 +0200 @@ -36,6 +36,7 @@ #include <linux/kernel.h> #include <linux/net.h> #include <linux/socket.h> +#include <linux/compat-2.6.h> #include <net/sock.h> #include <linux/in.h> #include <linux/slab.h>
This patch modifies the tcp_utils.h file inside the ofed-driver.tar.gz which is contained in the ofed-driver-3.3-1.src.rpm file in thge src directory.
Hope it helps.
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hope it helps.
