Software Archive
Read-only legacy content
17060 Discussions
Issue on compiling for iOS
Marcondes__Marcos
Hello
I already compile for iOS with sucess on this app on 4.1.2 and 5.1.1 cordoba
I changed some html code only and getting issue like images and code below
John_H_Intel2
    /usr/bin/codesign --force --sign CE5D61CC8A6C4F05A8561ADFA93E24DE05530C08 --resource-rules=.../CarolZerbini2/platforms/ios/build/device/Gestão\ de\ Coordenadores\ BT.app/ResourceRules.plist --entitlements .../CarolZerbini2/platforms/ios/build/Gestão\ de\ Coordenadores\ BT.build/Release-iphoneos/Gestão\ de\ Coordenadores\ BT.build/Gestão\ de\ Coordenadores\ BT.app.xcent .../CarolZerbini2/platforms/ios/build/device/Gestão\ de\ Coordenadores\ BT.app
CE5D61CC8A6C4F05A8561ADFA93E24DE05530C08: no identity found
Command /usr/bin/codesign failed with exit code 1
** BUILD FAILED **
This means that your provisioning profile does not match your cert. The last time you successfully built this app for iOS was back in Jan. Have you revoked your apple cert or did it expire recently?
Marcondes__Marcos
OMG thanks
I will check or even create a new one ... I have membership till january 2017 !!
thanks again
I will post here again any other issue or if this solved the issue !
