Software Archive
Read-only legacy content
17061 Discussions
Issue on running avd emulator
Massimo_S_
I have an issue when try to launch an android emulator through AVD Manager.
I tried using only android sdk or installing full android studio.
Clicking on play button, avd try to lunch the emulator, but when the progress bar is complete, it disappears, but nothing happens.
From event viewer I received the following error:
Application name that generated error: emulator-x86.exe, version: 0.0.0.0, timestamp: 0x5581d229
Module name that generated error: ig75icd32.dll, version: 10.18.10.4061, timestamp: 0x548e64f0
Exception code: 0xc0000005
Offset error: 0x001367ad
Process ID that generated error: 0x2234
Application startup time: 0x01d0d5ab91aeaa30
Application path: C:\Users\xxyyzz\AppData\Local\Android\sdk\tools\emulator-x86.exe
Module path: C:\windows\system32\ig75icd32.dll
Warning ID: ef9db8f4-419e-11e5-b516-e4ad885ba36a
Attached to this post you can found output of cmd command "sc query intelhaxm", CrystalCPUID screenshot.
Please may you help me to solve this issue?
Many thanks
