Software Archive
Read-only legacy content
17060 Discussions
Issue with License Servers - FLEXlm
ganesh82
We have an Intel12 license(for C++ and Fortran compiler for Intel64 system, Linux Platform) valid till 28th July, 2012. And suddenly we are facing issue with the License Manager. The problem description is as below:
JenniferJ
I'm moving your question to another forum for license issues.
Jennifer
ganesh82
Please let me know how to resolve this issue.
Please let me know whether renewing my license will resolve this issue.
ganesh82
Output of lmstat is as follows:
$ ./lmstat
lmstat - Copyright (c) 1989-2003 by Macrovision Corporation. All rights reserved.
Flexible License Manager status on Tue 4/3/2012 16:51
License server status: 28518@pasuse10
License file(s) on pasuse10: /opt/intel/licenses/*.lic:/opt/pgi/license.dat:/home/gan/comp/icc/redhat-flexm/flexlm/server.lic::
lmgrd is not running: Server node is down or not responding (-96,482)
Anonymous66
Valued Contributor I
Hello Anupama,
I am investigating your issue and will get back to you shortly with more information.
I have marked some of your posts private because they contain sensitive information.
Annalee Embry
Intel Developer Support
Anonymous66
Did youcheck that the server is running? This issue could be caused by a firewall. Did you make sure that the port is open?
If that doesn't work, try upgrading to the latest version of FLEXlm* in theregistration center.
ganesh82
My license server pasuse10 does not have access to internet , could this be cause for this issue.
Does license server pasuse10 need to have internet access , if so then what sytem and at what port will it try to connect via internet
Here are some details to answer questions in your previous post
1) lmgrd.intel is listening at port 28518
netstat -tulpn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:43104 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:2049 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:389 0.0.0.0:* LISTEN 4347/slapd
tcp 0 0 0.0.0.0:5989 0.0.0.0:* LISTEN 3406/owcimomd
tcp 0 0 0.0.0.0:28518 0.0.0.0:* LISTEN 12489/lmgrd.intel
tcp 0 0 0.0.0.0:5801 0.0.0.0:* LISTEN 4004/xinetd
tcp 0 0 10.138.140.133:427 0.0.0.0:* LISTEN 3303/slpd
tcp 0 0 127.0.0.1:427 0.0.0.0:* LISTEN 3303/slpd
tcp 0 0 0.0.0.0:5901 0.0.0.0:* LISTEN 4004/xinetd
tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 3352/portmap
tcp 0 0 0.0.0.0:790 0.0.0.0:* LISTEN 4331/rpc.mountd
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 4112/sshd
udp 0 0 0.0.0.0:2049 0.0.0.0:* -
udp 0 0 0.0.0.0:32770 0.0.0.0:* -
udp 0 0 0.0.0.0:789 0.0.0.0:* 4331/rpc.mountd
udp 0 0 255.255.255.255:427 0.0.0.0:* 3303/slpd
udp 0 0 10.138.140.133:427 0.0.0.0:* 3303/slpd
udp 0 0 224.0.1.22:427 0.0.0.0:* 3303/slpd
udp 0 0 239.255.255.253:427 0.0.0.0:* 3303/slpd
udp 0 0 0.0.0.0:111 0.0.0.0:* 3352/portmap
2) Flexlm download link is unavailable, I tried following links.
Please point to location where i can download flexlm lincense server
http://software.intel.com/en-us/articles/performance-tools-for-software-developers-intel-flexlm-license-servers/?wapkw=flexlm
https://registrationcenter.intel.com/RegCenter/Download.aspx?productid=633
Anonymous66
The license server does not need access to the internet.
2) The license server is no longer publicly available. You can download the latest version of the license server fromthe Intel Registration Center.
