I am building an enterprise application and having issues on build. I have p12 file created using Open SSL and when I upload the p12 file on the build page with the correct password, the XDK determines this as Invalid P2 or password? I am sure the password is correct and don't know what is causing this error. Any solution or insights will be helpful.
- Tags:
- HTML5
- Intel® XDK
Are you using the regular version of Intel XDK or the Early Access version? Did you create your certificate using the csr file provided by XDK? The XDK Build page requires the use of a cer file. Currently we are no longer taking .p12 files.
Did you follow these instructions?
https://software.intel.com/en-us/xdk/articles/walkthrough-export-p12-file
You might find this useful
https://software.intel.com/en-us/forums/intel-xdk/topic/550991
