Software Archive
Read-only legacy content
17060 Discussions
RealSense + EmguCV
Pol_P_
I am trying to smooth a depth image acquired with RealSense and then project it to world coordinates using PXCMProjection. My code is in c# and I am trying to use EmguCV library to perform the smoothing operations on the image. I keep running in formatting errors.
Here is my code:
public static PXCMPoint3DF32[] toDepthData(PXCMImage image, PXCMProjection proj)
    PXCMImage.ImageData data;
    image.AcquireAccess(PXCMImage.Access.ACCESS_READ, out data);
    PXCMPoint3DF32[] pts= new PXCMPoint3DF32[image.info.width * image.info.height];
    proj.QueryVertices(image, worldPts);
    image.ReleaseAccess(data);
    image.Dispose();
    return pts;
public PXCMPoint3DF32[] smoothDepthData(PXCMSession session, PXCMImage image, PXCMProjection proj)
    // get image info
    PXCMImage.ImageInfo info = image.info;
    // get image data
    image.AcquireAccess(PXCMImage.Access.ACCESS_READ, PXCMImage.PixelFormat.PIXEL_FORMAT_DEPTH, out data);
    // create a bitmap from the image data
    Bitmap dBmp = data.ToBitmap(0, info.width, info.height);
    // release access to original image and dispose
    image.Dispose();
    // create a opencv image
    Image<Gray, byte> dImg = new Image<Gray, byte>(dBmp);
    // performing some OpenCV smoothing operations here
    // convert opencv image to bitmap
    dBmp = dImg.Bitmap;
    // create new PXCMImage with the same dimensions as the original
    PXCMImage smooth = session.CreateImage(info);
    // get access to the data of the new image
    PXCMImage.ImageData sData;
    smooth.AcquireAccess(PXCMImage.Access.ACCESS_WRITE, PXCMImage.PixelFormat.PIXEL_FORMAT_DEPTH, out sData);
    // copy bitmap data
    BitmapData smoothData = new BitmapData();
    smoothData.Scan0 = sData.planes[0];
    smoothData.Stride = sData.pitches[0];
    smoothData.PixelFormat = dBmp.PixelFormat;
    smoothData.Width = dBmp.Width;
    smoothData.Height = dBmp.Height;
    BitmapData finalData = dBmp.LockBits(new Rectangle(0, 0, dBmp.Width, dBmp.Height), ImageLockMode.ReadOnly | ImageLockMode.UserInputBuffer, dBmp.PixelFormat, smoothData);
    // relese image data
    smooth.ReleaseAccess(sData);
    dBmp.UnlockBits(finalData);
    return toDepthData(smooth, proj);
    smooth.Dispose();
My problem is that I only can transform PXCMImage instances with PixelFormat.PIXEL_FORMAT_RGB32 successfully into Emgu Image instances. When I try to use PixelFormat.PIXEL_FORMAT_DEPTH it generates a 'Parameter is not valid' exception in Emgu.
On the other hand, If I process the image in RGB32 I have no problem transforming into Emgu but, when I transform it back to PXCMImage, the depth values generated are off.
Any ideas would be appreciated. Thanks!
Pol_P_
To expand on the question, I printed some of the values obtained with the RGB32. This values come from the following chain of transformations:
PXCMImage -> Bitmap -> Emgu Image<Bgr, byte> -> Bitmap -> PXCMImage
To clarify, I am not doing any openCV operations on the converted image; just converting it back and forth.
Here are the values that I get for the point (200, 200) before (*1*) and after (*2*) transformation in 5 consecutive frames:
*1* (200,200) > x: -357.7245, y: 95.45338, z: 1673
*2* (200,200) > x: -6484.37, y: 1730.256, z: 30326
*1* (200,200) > x: -362.4285, y: 96.7086, z: 1695
*2* (200,200) > x: -6814.084, y: 1818.236, z: 31868
*1* (200,200) > x: -367.5603, y: 98.07792, z: 1719
*1* (200,200) > x: -367.1326, y: 97.96381, z: 1717
*2* (200,200) > x: -6099.704, y: 1627.614, z: 28527
*1* (200,200) > x: -352.3789, y: 94.02699, z: 1648
*2* (200,200) > x: -6539.323, y: 1744.92, z: 30583
*1* (200,200) > x: -361.3594, y: 96.42332, z: 1690
*2* (200,200) > x: -6759.132, y: 1803.572, z: 31611
Again, any thoughts are welcome! Thanks!
