Software Archive
Read-only legacy content
17060 Discussions
Issues with the product documentation
Wei_Pan
Hope someone will fix them.
(0) Example code could be well-aligned, quite a few places.
(1) There are a number of places with "Note iconNote" or "Tip iconTip".
(2) Missing a ")"
__declspec (vector (optional clauses) return_type function_name (arguments)
(3) int -> float for the array type
Why not use cilk_for rather than openmp here? (as the specification)
void saxpy_vec(int m, float a, float x, float y){
y[:]+=a*x[:];
void main(void){
int a[2048], b[2048] ;
#pragma omp parallel
for (int i = 0; i < 2048; i +=256){
saxpy_vec(256, 2.0, &a, &b);
(4) "i=j" --> "i - j" ??
for (i=0; is = 0
for (j=0; j s+= x[i=j] * c;
y = s;
(5) Mixing Windows and Linux syntax
"icl -Qopenmp -Qstd=c99 test.c"
(6) Missing ";",
"j" should be "int j" to be a valid cilk_for
_Cilk_for (j = 0; j < n; ++j) {
a = ef_add(b,c)
Barry_T_Intel
Thanks for the suggestions and fixes!
Which sample applications or documents are the problems located in?
- Barry
Wei_Pan
Barry_T_Intel
I've passed these onto the technical writer for correction. She asked which OS and browser you are using, since that might effect how some of the document is displayed.
Thanks again for your assistance!
- Barry
Brandon_H_Intel
If you go to the updated 12.1 User's Guide (for example, the C++ for Windows one is at http://software.intel.com/sites/products/documentation/hpc/composerxe/en-us/2011Update/cpp/win/index.htm ), most of these issues are addressed. The only two that still exist that I see are #5 which should be addressed, and #6 which is not true if you write the _Cilk_for in C and not C++, so the sample code given is valid in that context.
Wei_Pan
Thanks for the pointer.
Seemly this is not a OS problem (I was using firefox under ubuntu 10.10). With the document from
those icons are back.
I am pretty sure there is a typo with "int a[2048], b[2048] ;" (should be of type float).
Sample code like
- Gather and Scatter example
- FIR scalar code
- Using Holders - An example
look not so great.
