Software Archive
Read-only legacy content
17060 Discussions
Keep the console window open after debugging
Intel_C_Intel
When debugging a DOS console app, Is there some way to prevent the console window from automatically closing after the program finishes? I would like to be able to scroll through the console window after the app has closed to inspect its output.
The simplest solution I can think of is to put a prompt for input at the end of the program, so it doesn't exit. I haven't tried this, but perhaps if you started DFDEV from a command prompt, the program's output would be in that command prompt window.
Steve
