Software Archive
Read-only legacy content
17060 Discussions
Kernel diver for virtualization?
Péter_Szilágyi
I've been reading up on the Intel-VT and the VMX instructions, but it seems that in order to get the CPU into a VMX-ready state I need to modify the CR4 register, which can only be done from within the kernel (at least under Windows). My problem is that I would like to write a dead-simple driver that only turned on the VMX operations and maybe did some minor housekeeping, yet to install this drvier under 64bit Windows I need to digitally sign the driver... which would cost hundreds of dollars. Why do I need kernel access in order to be able to write a small hypervisor for my project? As a university student I have absolutely no means of paying for the required certificates from VeriSign or whatever.
How is this issue solved with other projects? Does every single project that use Intel-VT pay for special certificates and such, or am I missing something? Is a pricey certificate needed for every single open source project that would like to use virtualization one way or the other?
Have a nice day,
Peter
hellfire
Ring0 privilege level is required to turn on VMX. The problem with drivers signing is related to Microsoft. It is not a problem to obtain a certificate from one of providers (verisign.com, globalsign.com) for commercial project.
For educational purposes one of following can be done:
2) Boot Windows with disabled driver signature enforcement
Péter_Szilágyi
Actually I was thinking about more than educational purpose and less than commercial (i.e. an open source project).
My question though is why do I need Ring0 privilege level?
hellfire
This is requirement of IA-32 architecture. To enter VMX operation, CR4.VMXE bit must be set. Writing to CR4 can be done with Ring0 privilege (CPL=0) only. Otherwise #GP(0) exception will be raised by processor.
Péter_Szilágyi
I know *why* practically (to edit the register), but *why* theoretically? Why couldn't vritualization always be enabled?
hellfire
Quoting - Pter Szilgyi
Theoretically - due to security reasons. It is not acceptable to let any user mode software manipulate system registers and turn virtualization on.
