Software Archive
Read-only legacy content
17060 Discussions
Knights Landing Software Stack installation troubles
ketancmaheshwari
Intel's new Knight's Landing processor has builtin support for hosting OS and is no more a pluggable card MIC as in the traditional systems. Now when I try to install the MPSS one of the step is to detect MIC with the following command:
$ sudo micctrl --initdefaults
I get:
[Warning] No Mic cards found or specified on command line
However, in this new architecture of Intel xeon phi there is no Mic expected since the main processor itself is Mic.
So, my question is, how to tell the system that there is no Mic or how to workaround this situation in order to correctly install MPSS. I am using CentOS 7 and MPSS version 3.7.1. The CPU specs are Intel(R) Xeon Phi(TM) CPU 7210 @ 1.30GHz model 87.
jimdempseyatthecove
The Knights Landing is a Host CPU (at this time), and therefore does not require (use) mpss.
Effectively this is a native mode only system. Your programs would not use offload programming. And you do not ssh to it from the same system.
Jim Dempsey
Gregg_S_Intel
Intel MPSS is software for host + Intel Xeon Phi x100 coprocessors (formerly codenamed Knights Corner).
It does not apply to systems with Intel Xeon Phi x200 processor formerly codenamed Knights Landing.
The latter are standalone systems booting standard Linux distributions, backward compatible with Intel Xeon processors.
Loc_N_Intel
There webpage for Intel(R) Xeon Phi(TM) Processor is shown here https://software.intel.com/en-us/xeon-phi/x200-processor . Also the Intel(R) Xeon Phi(TM) Processor software is posted here: https://software.intel.com/en-us/articles/xeon-phi-software
SuperHT
Does KNL x200 have unofficial support for Ubuntu 16.04, similar to what we had for x100 (KNC / MPSS) ? Is there a way to compile xppsl_1.5.0 on Ubuntu.
Thank You.
