Software Archive
Read-only legacy content
17060 Discussions
LAN connection not restarted on power up - Arduino/Galileo project
Jason_T_1
My first impression of working with the Galileo is to put it in the box and send it back.
Im happy with the open source environment which has grown quite rapidly with the birth of the arduino, i was hoping that the Galileo was going to be straight forward. Wrong.
Ok so what did i dislike having to discover how to re flash it before i could even get it working. no instruction in box for basic setup only pointers to intels corporate site. incidently its a nightmare to trawl through to find this forum.
power up sequence, dont plug in USB lead first or it will destroy your board, what sort of product is this. A known issue in a production board.
i tried to register my product, it apparently does not exist even though its 100% genuine from Amazon, so i cant register it.
Using the Galileo as an Arduino after all the hick-ups i do have a working application, control for an AUV over LAN.
like most things it is likely to be switched off at night. Unfortunately the Network connection does not reopen unless i reload the arduino sketch
any help to fix this or a work around would be very much appreciated.
otherwise its going back in the box.
Cheers
MikeP_Intel
Thanks for your candid feedback.
wrt to having to reload the sketch on power-up. I suggest that you obtain a 8GB micro SD card and download the "expanded" boot image and load it on same SD card:  https://software.intel.com/en-us/iot/downloads & https://software.intel.com/sites/landingpage/iotdk/board-boot-image.html
