Software Archive
Read-only legacy content
17060 Discussions
LINK : fatal error LNK1104: cannot open file "dformd.lib"
Deleted_U_Intel
Hi everyone,
I have problem with environment variables. How to change them that fortran would work with abaqus 6.2
If you are not linking from the command line, then environment variables don't matter. If you are using the command line, make sure that the LIB variable contains the path to the ..DF98LIB folder.
Steve
