Sergey Kostrov wrote:
Hi everybody,
Subject is: Laptop SODIMM memory with 9-9-9-24 latency vs. 10-10-10-27 latency ( Non-ECC ).
I'm considering to buy a laptop SODIMM memory ( 8GB x 2 ) and my questions are:
- Which one is better in terms of performance ( latency )?
- What else has to be taken into account when selecting a laptop SODIMM memory?Thanks in advance.
Read this link:http://en.wikipedia.org/wiki/SDRAM_latency#Measurements
Do you think that one cycle more or less will be significant for you.
Hi!
This link has basic info about the memory measurement :http://en.wikipedia.org/wiki/SDRAM_latency#Measurements
Do you have special needs for low latency memory?
>>...Do you have special needs for low latency memory?
Yes because I'd like to have the same type of SODIMM memory in all four memory slots, that is, 1600 MHz and the same timings.
By writing "needs" I mean any kind of software which will benefit from the low latency memory.
>>>Thanks for your time >>>
No problem.We are here to help each other.
