Software Archive
Read-only legacy content
Layout of app
James_W_2
What are the advantages and disadvantages of separating content using different panels, views or files?
Also, how can I control which view is currently visible? At the moment all views are visible simultaneously when I launch the app underneath each other, although only one is set to active in the debugger.
Elroy_A_Intel
This question is very open ended. I recommend that you evaluate the needs of your project as this will help you govern what HTML5 or JavaScript framework and approach makes sense to you.
