Software Archive
Read-only legacy content
17060 Discussions
License File for Evaluation version not provided
Nicoletta_M_
Dear Sir,
I am attempting to evaluate Parallel Studio XE 2015 for Linux. However, the installation requires the use of a license file when installing the product without root access. Supposedly, "you will have received a confirmation email with an attached license file", but no such license file was attached to the confirmation email I received.
Can I have the email/license file resent so that I can install and evaluate the product?
Thank you,
Nicoletta
Hubert_H_Intel
Nicoletta,
The process has changed. For evaluation registrations, no license files nor serial numbers are being delivered any longer. The default activation mode shall be the "Evaluation Activation" that doens't require any license file nor serial number.
I've sent you the license file. However, eval activation/installation in user mode should be possible (although we suggest to install an eval with root rights to have full functionality of all components available with the product). Did you try a user installation? Can you share the error message?
Regards, Hubert.
