Software Archive
Read-only legacy content
17060 Discussions
License file nor serial number will work with newest Composer XE
jeromy
I am trying to install Composer XE 2013 SP1 1.106 using a serial number that has support through Sep 2014 and I am getting the following errors:
The serial number you provided is not valid for this product.
or
The license file(s) you provided is not valid for this product.
Any ideas why this would be happening?
Jerry_S_
Having the same problem and posted it last week on this forum.  Intel is suspiciously silent and has yet to post a response.
Jerry_S_
QIAOMIN_Q_
Could you provide your serial numbers in private messages? I would like to check for you.
Qiao
jeromy
Solved my problem.  In my case, it turned out to be because /tmp was not executable. After launching the installer with -t /usr/tmp, it worked fine.
