Software Archive
Read-only legacy content
17060 Discussions
License problem- Intel Fortran Compiler
Pipa
Hi All,
The Intel Fortran compiler was working fine on my machine for past few days. I got into an error today with the compiler. The error messages I get whenever I try to compile with MS Visual Studio are:
Error 1 Error A license for FCompW is not available now (-15,10,10061).
Error 2 error #10052: could not checkout FLEXlm license ifort
When I just type ifort on the command line, then I get the following error message:
ifort error #10310: Failed to enable trusted storage check for licensing: Warning" Enable Trusted Storage failed (flexnet error code 20). Trusted Storage based licence could
I tried disabling firewalls for my network but it still didn't work. Would somebody please help us here?
Ron_Green
Quoting - B
Hi All,
Moving to the User Forum for licensing problems.
ron
Shamla_P_Intel
Greetings,
Did you change the OS version? Did you download a new package of our product? Did your license server change?
If nothing changed on your system, I don't see any reason why you get an error, other than if your license expired and you installed a new product package.
This is an error reported by some other customers with floating license. There is a fix in the license server and the new license server is posted at http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22license+server%22
Can you please try the new license server and let me know if this fixes this issue?
Thank You
Shamla
Pipa
Quoting - Shamla (Intel)
Greetings,
Thank You
Shamla
Hi Shamla,
We updated from 11.1 build 38 to the newer build 46, running a floating license server on a windows vista x64 machine. I'll try the new license server to see if that works.
Shamla_P_Intel
In the meantime, the Flexlm team wanted you to check the following.
Set environment variable LD_LIBRARY_PATH to include the path name for *_libFNP.so
This is usually done by sourcing a predefined script, e.g.
source /opt/intel/Compiler/11.1/043/bin/iccvars.sh ia32
Thank You
Shamla
