Software Archive
Read-only legacy content
17061 Discussions
Licensing error for Evaluatoin Version Intel Fortran Composer XE for Mac
julienvancampen
I just installed the trial version of Intel Fortran Composer XE for Mac. I wanted to give it a test run from the command line in Terminal, and got the following error:
"ifort: error #10310: Failed to enable trusted storage check for licensing: WARNING: Enable Trusted Storage failed (flexnet error code 1). Trusted Storage based license could not be supported"
In the e-mail with the link to download the software there is also a license file provided. My questions are:
* Would this error be resolved if I place the provided license file in the appropriate folder?
* If yes, which folder should I put the license file in?
Many thanks in advance,
Julien
Igor_V_Intel
Here are a couple things to try, the first is from this forum thread: http://software.intel.com/en-us/forums/showthread.php?t=79639
1. When registering for the Intel Fortran Composer XE 2011 for Mac OS X evaluation you should have received a license file via email. Place that license file on your system (as root) into /Users/Shared/Library/Application Support/Intel/Licenses and then set the permissions to include group/other "read" at least (i.e. use chmod file mode bits of at least "644").
2. Try compiling a trivial Fortran program via the ifort command line and include the -V option and verify the version of the compiler is as shown below.
$ ifort -V hello.f90
Intel Fortran Intel 64 Compiler XE for applications running on Intel 64, Version 12.0.1.122 Build 20101110
Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
Intel Fortran 12.0-1230
@(#)PROGRAM:ld PROJECT:ld64-97.17
3. If the simple command-line compilation succeeds, then open your Xcode solution and
a. Select/highlight (left-click) your executable under Target, right-click and select Get Info.
b. On the Rules tab, look for the Default Fortran rule and ensure it is set to "using: Intel Fortran Compiler XE 12.0 (Limited Feature)". Yours is likely set to use something like "Unknown compiler com.intel.compilers.ifort.11_0_0".
c. Once the 12.0 compiler is selected, dismiss the Info sub-window and try rebuilding your target.
If that doesn't help, the second succestion is from this thread: http://software.intel.com/en-us/forums/showthread.php?t=67050
cd /opt/intel/Compiler/11.1/038/bin/
source ifortvars.sh ia32
ifort -V
Your directory structure may differ, but essentially you want to source the .sh file (you may need to pass intel64 instead of ia32 if you're on a 64 bit system). You probably won't be in 11.1 but 12.0 directory also.
Please let me know if ether of these solutions work for you or if there are still errors.
