Software Archive
Read-only legacy content
17061 Discussions
Licensing issue with icc
W_W_
Hello there,
I recently downloaded and registered the Intel® Parallel Studio XE Composer Edition for C++ OS X* (student version), however when I tried to compile some code with it, I got the following errors:
Error: A license for CCompM is not available (-8,130).
License file(s) used were (in this order):
    1.  Trusted Storage
**  2.  /usr/bin/icc-15.0-base/bin/intel64/../../Licenses
**  3.  /Users/WEI/Licenses
**  4.  /opt/intel/licenses
**  5.  /Users/Shared/Library/Application Support/Intel/Licenses/license_ism2_85V_xxxxxxxxx.lic
**  6.  /Users/Shared/Library/Application Support/Intel/Licenses/license_ism2_GLK_xxxxxxxxx.lic
**  7.  /Users/Shared/Library/Application Support/Intel/Licenses/license_ism2_W4F_xxxxxxxxx.lic
**  8.  /Users/Shared/Library/Application Support/Intel/Licenses/m_5X3GPCSC.lic
**  9.  /usr/bin/icc-15.0-base/bin/intel64/*.lic
Please visit http://software.intel.com/sites/support/ if you require technical assistance.
icc-15_0: error #10052: could not checkout FLEXlm license
Command /usr/bin/icc-15.0 failed with exit code 1
*I have masked out the serial #  from the error message.
What could be the problem?
Tha\nks
Wei
Feilong_H_Intel
Hi Wei,
Could you please remove all .lic files except m_5X3GPCSC.lic, and try to run the compiler again?  Please let me know if it solves the problem.
