Hi to all,
Ever since we upgraded to 12.1.1 we have started experiencing slow compilations at one of our sites. The licensing debug file indicates that the compiler is looking for a feature called MICFCompW which we do not have and compilation does not proceed until this times out, a process which for one user is requiring 30 seconds for each source file. I would like to disable this feature check since it is clearly something we are not using.
The compiler should not be looking for a feature by that name. Please update to 12.1.4 (Update 10) and see if the problem persists.
Hi Steve,
I received an email notice that update 10 was available on May 2nd, but the download link in the email isn't working:
I've tried that. It tells me I don't have any products, which is not true. I also got a web page that said "critical system error, our staff will investigate immediately". It is kind of hard to get past that one.
I looked up my serial numbers and tried to register them, just in case I had forgotten to do this previously. When I press the "register" button I get the same page that says "critical system error".
I am moving this thread to our Download, Registration and Licensing forum where specialists will be able to help you.
Topic Options
