Software Archive
Read-only legacy content
17060 Discussions
Local wifi preview fail
sinisa_k_
Does wifi preview works at all?
it worked before but now iw updated XDK and i just cant preview anymore over wifi... either iOS or Android  :(
can anyone help?
John_H_Intel2
I have 2548 installed (latest) and testing over wifi works as it should with iOS and Android.
sinisa_k_
I was affraid of such answer... :(
Still, both of mine devices access internet through wifi and are in the same subnet as PC but preview wont start on both of them.
For example, cocoon JS local wifi preview works flawlessly.
Is there anything i can do (besides pointles clicking on that update server button) to make it work becouse alternate server upload testing is quite exhausting i must say.
Thank you.
Roi_D_
was joing going to open a thread for this as well. preview not working since latest xdk update. I use cable and it still complain on wifi. xdk doesn't recognize my device. clicking the help buttons in the xdk of both android and ios do nothing.
screenshot: http://prntscr.com/8o16ju
yes the phone is connected yes it is set to usb debugging. just after the xdk update it doesn't work.
Roi_D_
Got it working after multiple retries.
John_H_Intel2
Just for the record, using App Preview to test over wifi is NOT the same debugging using a USB cable to debug. These are 2 completely separate ways to test your app.
sinisa_k_
@JOHN H. (Intel)
any tips for me?
Roi_D_
right. I tested wifi preview to check if I have the issue reported here and it works for me.
sinisa, a tip i can suggest is maybe remove the check from "run intel xdk server" and check it again and if see if you'll get a popup from Windows asking if to approve opening a listening port. in any way rechecking the checkbox seems to use a different port each time so it might solve the problem for you by just using a different port.
