Software Archive
Read-only legacy content
17060 Discussions
Dowload link for v1494
Elisa_M_
Hi, I'd need to download v1494 of intel XDK software, is it possible?
John_H_Intel2
Can I ask why you need this particular version?
Honestly, I dont know if you did have it that it would work the current build system.
Elroy_A_Intel
We do not recommend previous releases of Intel XDK since the latest version address bugs and provides up to date features not found in prior versions.
Elisa_M_
Hi and thank you for your answers
Yes, I know...
The reason I'm asking it is because we have a really old project that we won't develop anymore with XDK but we're using it as a prototype.
Now we'd need to do some little modification at the ui, but since I've updated the software I'm having a lot of issues
Anusha_M_Intel1
We strongly encourage our users to use the latest release. But I can also understand where you are coming from. Could you elaborate on what are the issues deterring you from modifying the UI? Are you using app designer? If so, I could request someone from the app designer team to help you.
Amrita_C_Intel
You can still run your old projects in the latest version.
Elisa_M_
@Amrita
Unfortunately no, I wasn't able to run my project in the latest version, when I tried I received this error:
Unexpected call to process.exit()
an I wasn't able to solve it.
@Anusha
Finally I solved (I was using v1621 that fortunately is still available for downloading)
The app was crashing at the opening on some devices, I investigated a little bit with adb logcat and I discovered that the problem was due to splash screen image at lower resolutions
Anyway, thank you!
Amrita_C_Intel
I am glad it is working!
