Software Archive
Read-only legacy content
Login screen does not open on Ubuntu 14.04
Luke_M_1
Problem
I cannot get to the login page after I open Intel XDK. There is a loading wheel that just spins forever until an error message comesup  with the error 'Attempt to contact authentication server is taking a long time. You can wait, or check your network connection and try again.'. My network connection is not modified in anyway, literally just a computer connected to a switch which is connected to a fibre-optic router. There are no proxy settings in the way.
What I did from the beginning until I noticed the problem
I noticed an issue when I attempted to download the application from https://software.intel.com/en-us/intel-xdk on my Ubuntu machine. The download just stalled at 'initialising' until an error message popped up (which I have since forgotten but was something to the effect of it is taking too long to start the download). I went to a windows computer and the download worked as expected. I then copied the install file onto a USB and installed it on my Ubuntu machine. After installing, I clicked 'Sign up' on the in-app prompt. This opened as expected and I was able to create an account. However, after the dialogue closed, the translucent black overlay remained and I was unable to do anything on the application. There were no loading indicators. I restarted XDK and attempted to login (this was when I noticed the problem). To make sure that the sign up process actually went okay, I attempted to login using a browser. I got a certificate error for sfederation.intel.com (server's certificate violates name constraints). After proceeding by clicking continue in the more info section, I was able to login.
System Config
Ubuntu 14.04 (64-bit)
Chrome
 46.0.2490.86 (64-bit)
Intel Core i7-3930K
8GB RAM
Swati_S_Intel1
What's your username for the new account that you created? When did you create the account? Please send the screenshots of the errors..
Luke_M_1
Username: lmadhanga
Created: 17 Nov 15:00
Luke_M_1
Here is a log of a startup incase it is useful:
Swati_S_Intel1
Hi Luke, there is some maintenance work going on for Enterprise login servers which could have affected your login, I'll check with that team to see what's going on. Meanwhile could you try few things and let me know:
1) You mentioned you were not able to download the XDK on your Ubuntu machine. Are you able to download now without any trouble?
2) The login problem could be temporary, try again and see if it works. Try to login at signin.intel.com using your credentials (from Ubuntu as well as Windows machine) and let me know if that works and what's the difference.
3) Please double check your network setting, make sure you have no system wide proxy set.
4) If you are able to login at signin.intel.com then uninstall the XDK completely and re-install
Luke_M_1
Thank you for your response.
I attempted to download XDK from my Ubuntu machine and was unable to do so
I have to click on trust certificate If I am to login to the intel site
My Network settings are definitely at their default setting
I have just reinstalled XDK to no avail
Swati_S_Intel1
Hi Luke,
Please run this command and send me the output.
openssl s_client -showcerts -connect sfederation.intel.com:443
To come out of openssl press Ctr-C.
Luke_M_1
Hi Luke,
CONNECTED(00000003)
depth=3 C = SE, O = AddTrust AB, OU = AddTrust External TTP Network, CN = AddTrust External CA Root
verify error:num=19:self signed certificate in certificate chain
verify return:0
Certificate chain
 0 s:/C=US/ST=CA/L=Santa Clara/O=Intel Corporation/CN=sfederation.intel.com
   i:/C=US/ST=CA/L=Santa Clara/O=Intel Corporation/CN=Intel External Basic Issuing CA 3B
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
 1 s:/C=US/ST=CA/L=Santa Clara/O=Intel Corporation/CN=Intel External Basic Issuing CA 3B
   i:/C=US/O=Intel Corporation/CN=Intel External Basic Policy CA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 2 s:/C=US/O=Intel Corporation/CN=Intel External Basic Policy CA
   i:/C=SE/O=AddTrust AB/OU=AddTrust External TTP Network/CN=AddTrust External CA Root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 3 s:/C=SE/O=AddTrust AB/OU=AddTrust External TTP Network/CN=AddTrust External CA Root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Server certificate
subject=/C=US/ST=CA/L=Santa Clara/O=Intel Corporation/CN=sfederation.intel.com
issuer=/C=US/ST=CA/L=Santa Clara/O=Intel Corporation/CN=Intel External Basic Issuing CA 3B
No client certificate CA names sent
SSL handshake has read 7305 bytes and written 663 bytes
New, TLSv1/SSLv3, Cipher is AES256-SHA256
Server public key is 2048 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
SSL-Session:
    Protocol  : TLSv1.2
    Cipher    : AES256-SHA256
    Session-ID: C8B93E73229622AAA70AFDACFFD7D01FB4E9EB4D90B61CC0BD03C2BC4BC1D06A
    Session-ID-ctx:
    Master-Key: 85113AFECD6CA8894D13FFD5AE61310152DD659EDEF37F91E17AA084AC6302ECB22BA4083FBD3A06B4A1855DD0C000F2
    Key-Arg   : None
    PSK identity: None
    PSK identity hint: None
    SRP username: None
    Start Time: 1448010579
    Timeout   : 300 (sec)
    Verify return code: 19 (self signed certificate in certificate chain)
Note
Before I opened this support ticket, I thought that (because Chrome was complaining about certificates and refusing connections) there may have been a system wide certificate issue and the XDK was failing silently because of that. I attempted to install a system wide certificate allowing sfederation.intel.com, but that did not help, so I uninstalled it. Also, I have told Chrome to allow sfederation.intel.com
Swati_S_Intel1
Hello Luke,
Could you check one more thing? Please load the site https://sfederation.intel.com/ in chrome browser, click on the  lock iconLock or page iconBlank page icon. Under the connections tab there is "Certificate Information" link. Please click on that and send me the screenshot.
Luke_M_1
Hello Luke,
Could you check one more thing? Please load the site https://sfederation.intel.com/ in chrome browser, click on the  lock icon or page icon. Under the connections tab there is "Certificate Information" link. Please click on that and send me the screenshot.
Note, the invalid certificate being spoken of is the one created when you click 'Proceed to website.com' in Google Chrome
Swati_S_Intel1
Hi Luke,
Can you run this command and let me know the output?
sudo dpkg -s libnss3 | grep Version
There was a libnss bug that could cause this issue. If your version isn’t 2:3.17-0ubuntu0.14.04.1 or later then run “sudo apt-get update ; sudo apt-get upgrade” command to upgrade the necessary packages.
Luke_M_1
Hi Luke,
Hello, I was running an old version of libnss3. Running the apt-get command did not update my version (Anyone reading this in the future, do not manually install the latest version of libnss3, as I did. You'll find you no longer have internet when package dependencies fail!). I did however install Ubuntu 15.10, and I am now able to login. I can't however open my project (created on OS X El Capitan)
