Software Archive
Read-only legacy content
17060 Discussions
MKL Evaluation Download
vbc10
I installed the MKL library for the evaluation period less than a month ago. I am able to run my code in the debug mode using Visual Studio. However the release version has errors at run time stating the, "Application has failed to start because mkl_squential.dll was not found. Re-installing the application may fix this problem." I have tried re-installing, but the same error occurs. Did I install MKL incorrectly?
Chuck
New Contributor II
Greetings,
I would suggest you post this question to the MKL Forum. They may be more knowledgable about this particular error.
http://software.intel.com/en-us/forums/intel-math-kernel-library/
Thank you,
Chuck
