- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
I am trying to execute the Intel MPI benchmark in the following configuration: CentOS 6.5 with Intel MPI version 4.1.3.045 and MPSS 3.1.2, and OFED 1.5.4.1 installed from source. My network configuration is default (static pair produced by "micctrl --initdefaults"), and I have 1 node with two 3120A Xeon Phi coprocessors.
The MPI benchmark works just fine with fabrics "tcp" or "shm:tcp". Namely, I am able to run the benchmark between localhost and mic0, and between mic0 and mic1. However, with fabric "dapl", I cannot run IMB between localhost and mic0:
[bash]
$ export I_MPI_MIC=1
$ export I_MPI_FABRICS=dapl
$ mpirun -host localhost -n 1 /opt/intel/impi/4.1.3.045/intel64/bin/IMB-MPI1 PingPong : -host mic0 -n 1 /opt/intel/impi/4.1.3.045/mic/bin/IMB-MPI1
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= EXIT CODE: 139
= CLEANING UP REMAINING PROCESSES
= YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault (signal 11)
[/bash]
At the same time, fabric "dapl" works just fine (much faster than "tcp", actually) between two coprocessors mic0 and mic1:
[bash]
$ mpirun -host mic1 -n 1 /opt/intel/impi/4.1.3.045/mic/bin/IMB-MPI1 PingPong : -host mic0 -n 1 /opt/intel/impi/4.1.3.045/mic/bin/IMB-MPI1
benchmarks to run PingPong
# Intel (R) MPI Benchmark Suite V3.2.4, MPI-1 part
# Date : Sat Jan 4 21:05:43 2014
# Machine : k1om
# System : Linux
# Release : 2.6.38.8+mpss3.1.2
# Version : #1 SMP Wed Dec 18 19:09:36 PST 2013
# MPI Version : 2.2
# MPI Thread Environment:
... etc
[/bash]
Does IMB fail between localhost and mic0 because of the way that I am running it, or is there something that I should check in my configuration?
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Your mpirun command looks fine.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Check your MPI setup. This looks like and MPICH2 error message.
Similar topic: http://software.intel.com/en-us/forums/topic/405183
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I got help from an Intel engineer in private communication. The way to diagnose this issue was setting "I_MPI_DEBUG=5". The output of that command shows that memlock limit is too small. The solution is to edit /etc/security/limits.conf, and log out / log back in. The tail of limits.conf in my current (working) configuration is this:
[bash]
* soft memlock unlimited * hard memlock unlimited
* soft core 0
* hard core 0
[/bash]
Another issue is setting the provider of the DAPL fabric. For the ibscif virtual adapter (between CPU and MIC), the provider can be chosen by setting
[bash]
export I_MPI_DAPL_PROVIDER=ofa-v2-scif0
[/bash]
With these two tweaks, the MPI benchmark looks happy:
[bash]
# Date : Mon Feb 3 15:24:27 2014
# Machine : x86_64
# System : Linux
# Release : 2.6.32-431.el6.x86_64
# Version : #1 SMP Fri Nov 22 03:15:09 UTC 2013
# MPI Version : 2.2
# Benchmarking PingPong
# #processes = 2
... [ I had to delete some lines here because they were triggering the spam filter. This is annoying! ]
1048576 40 229.64 4354.72
2097152 20 379.80 5265.92
4194304 10 683.00 5856.54
# All processes entering MPI_Finalize
[/bash]
P.S.: I asked the question with Intel MPI 4.1.3.045, and the last listing is from Intel MPI 4.1.1.036, however, the fix applies to both versions.
P.P.S: I have been trying to post this message for a while and getting blocked by the spam filter. It occurs a lot on this forum.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Andrey,
Thanks for your contribution to the community.
I'll find out what is happening about the SPAM filter.
Taylor
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thanks, Taylor! From experience here and in nearby Intel forums, I feel that the spam filter dislikes multiple rows of tabulated numerical data, at least in the [bash*] listings.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Andrey, thanks for the feedback on the spam filter. I have a meeting w/ the spam filter vendor coming up and I'll bring this issue up with them specifically. Is it OK to have someone from our support team follow up to get more specifics about the types of messages that are being blocked?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Sure, thanks, I am already communicating with Hal regarding that.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
excellent I'll touch base w/ him tomorrow. Sorry about that Andrey and thanks for your patience. Hopefully we can use this data to make this work better for everyone in the future.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
