Software Archive
Read-only legacy content
17060 Discussions
MPI programs dont run on MIC's across nodes or within the nodes
aketh_t_
I am using the intel MIC to run sample MPI programs currently.
The program is a simple hello world program.
#include <stdio.h>
#include <mpi.h>
int main (argc, argv)
     int argc;
     char *argv[];
  int rank, size,len;
  char name[MPI_MAX_PROCESSOR_NAME];
  MPI_Init (&argc, &argv);      /* starts MPI */
  MPI_Comm_rank (MPI_COMM_WORLD, &rank);        /* get current process id */
  MPI_Comm_size (MPI_COMM_WORLD, &size);        /* get number of processes */
  MPI_Get_processor_name(name,&len);
  printf( "Hello world from process %d of %d with name as %s\n", rank, size,name );
  MPI_Finalize();
  return 0;
i compiled the program using hostfile option. mpirun -f machinefile -n 4 ./a.out
The contents of the machinefile is
cat machinefile
node1-mic0
node1-mic1
And the output i get is
Hello world from process 1 of 4 with name as node1-mic0
Hello world from process 2 of 4 with name as node1-mic0
Hello world from process 3 of 4 with name as node1-mic0
Hello world from process 0 of 4 with name as node1-mic0
However when i force the the program to split across the Intel MIC's, using the -ppn option, i encountered the following problem.
   mpirun -f machinefile -n 4 -ppn 2 ./a.out
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   EXIT CODE: 11
=   CLEANING UP REMAINING PROCESSES
=   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault (signal 11)
Artem_R_Intel
Which version of MPI do you use?
Could you please try to run simple system utility like 'hostname' (instead of a.out) with the same mpirun options?
Have you set any specific MPI environment variables? If yes please specify them.
aketh_t_
icc (ICC) 14.0.2 20140120
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
i had only set the I_MPI_MIC=enable.
i am sorry but i have no idea about system utilities such as hostname?
can you guide me in that aspect.
Am i supposed to try to call the hostname function is it?
aketh_t_
mpirun -f machinefile -n 16 -ppn 2 hostname
node1-mic0
node1-mic0
node1-mic0
node1-mic1
node1-mic0
node1-mic1
node1-mic1
node1-mic1
node2-mic0
node2-mic0
node2-mic0
node2-mic0
node2-mic1
node2-mic1
node2-mic1
node2-mic1
is does seem to work when i run hostname.
Artem_R_Intel
You've specified the Intel Compiler version.
Could you please try 'which mpirun' or 'mpirun -V' to get the exact version.
If not mistaken you use Intel MPI, so could you please run the original test scenario with the following environment variables I_MPI_DEBUG=6 and/or I_MPI_HYDRA_DEBUG=1.
Have you enabled IP forwarding as recommended in the Intel MPI User Guide?
11.2. Multiple Cards
To use multiple cards for a single job, the Intel® Manycore Platform Software Stack (Intel® MPSS) needs to be configured for peer-to-peer support (see the Intel® MPSS documentation for details) and the host(s) needs to have IP forwarding enabled.
(host)$ sudo sysctl -w net.ipv4.ip_forward=1
Each host/card should be able to ping every other host/card and the launching host should be able to connect to every target, as with a classic cluster.
