Software Archive
Read-only legacy content
MPSS 3.3 source building configuration problem
Pierre_L_
Greetings, I just installed the last MPS version 3.3 and all is fine, however I need to rebuild a kernel module and things are getting wrong. Before building anything, just preparing the environment it seems a reference to the user "sthampso" is unexpected:
[root@phi01 linux-2.6.38+mpss3.3]# make modules prepare
  CHK     include/linux/version.h
  CHK     include/generated/utsrelease.h
  CALL    scripts/checksyscalls.sh
  CHK     include/generated/compile.h
  /home/root/install/FhGFS/fhgfs-client-MIC/linux-2.6.38+mpss3.3/scripts/gen_initramfs_list.sh: Cannot open '/home/sthampso/new-kernel/make-2.6.38a/drivers/card/rootfs2'
make[1]: *** [usr/initramfs_data.cpio] Erreur 1
make: *** [usr] Erreur 2
I will adapt the config file accordingly to build my kernel module, but better to fix this in the distrib for everyone.
Pierre.
Loc_N_Intel
Hi Pierre,
If you rebuild a kernel module, you also need to rebuild the MPSS in order to make it work properly.
Thank you.
Evan_P_Intel
Unfortunately, and despite its suggestive name, config-mic-knc-2.6.38 is not, in fact, the kernel .config for the bzImage included in MPSS. Using it as the basis for your .config results in the error you're seeing, among others. Instead, you want to use /opt/mpss/3.*/sysroots/k1om-mpss-linux/boot/config-2.6.38.8+mpss3.*.
Exact directions for how to compile the MPSS Linux kernel from source can be found in this comment on an earlier forum thread. In particular, you may find the final "additional note" at the end of that comment relevant.
It's more nuanced than that.... Pierre, when you say you need to "rebuild a kernel module," you just mean that you need to rebuild a third-party, out-of-tree kernel module we don't ship with MPSS, correct? That won't require a massive rebuild.
Pierre_L_1
Thanks for your answers guys, yes my purpose was to build a third party our of tree kernel module, which was not that difficult once the .config was fixed. All is fine now, but your are the file config-mic-knc-2.6.38 is misleading.
Cheers, Pierre.
Holger_A_
I have the same problem with the sources. I want to build a third party kernel module (Xeon Phi support for BeeGFS, formerly known as FhgFS).
When I copy the /opt/mpss/3.3/sysroots/k1om-mpss-linux/boot/config-2.6.38.8+mpss3.3 and type "make modules prepare" I get the message
  CC      arch/x86/kernel/dumpstack.o
/root/mpss-3.3/src/linux-2.6.38+mpss3.3/arch/x86/include/asm/spinlock.h: Assembler messages:
/root/mpss-3.3/src/linux-2.6.38+mpss3.3/arch/x86/include/asm/spinlock.h:85: Error: no such instruction: `delay %ecx'
make[2]: *** [arch/x86/kernel/dumpstack.o] Fehler 1
make[1]: *** [arch/x86/kernel] Fehler 2
make: *** [arch/x86] Fehler 2
This is surely caused by the fact that the CentOS 6.5 I am using is running a 2.6.32 kernel, not 2.6.38. Where do I get the right config file for my kernel?
Holger
Evan_P_Intel
Actually, the problem is that you didn't tell Linux you're cross compiling, so it's trying to build with "gcc" instead of the "k1om-mpss-linux-gcc" provided with MPSS. I'd suggest "make ARCH=k1om CROSS_COMPILE=k1om-mpss-linux- modules prepare".
As I mentioned, I've written more about cross-compiling MPSS's Linux kernel from source here.
