- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Hi:
the host running on centos 7 has a new kernel Linux 3.10.0-123.20.1.el7.x86_64,
before mpss installation, I recompiled the mpss module and reflashed the firmware to 391 for mpss 3.4.3,
mic and mpss run well by using miccheck, mininfo, systemctl status mpss.
NFS server has been installed in the host with: yum install nfs-utils
rpcbind and nsf service are running well. firewalld and NetworkManger have been stopped. SELinux is disabled.
Basically all the steps are followed with <<Intel(R) Manycore Platform Software Stack MPSS 3.4.3 README>> and everything seems OK so far.
Then I started to mount NFS to mic0 which follows the steps from the section 5.6.3 in <<System Administration for the Intel® Xeon Phi™ Coprocessor MPSS 3.4 >>
### mounted NFS
1. Append /etc/exports on the NFS server with the line in the format:
/test 172.31.0.0/16(rw,no_root_squash)
2. Add in /etc/hosts.allow on the NFS server
ALL: 172.31.0.0/16
3. Let NFS know the files have changed by executing
> exportfs -a
4. Add an NFS mount entry to the Intel® Xeon Phi™ coprocessor’s /etc/fstab file. Execute this
command on Intel® Xeon Phi™ Coprocessor attached host system.
> micctrl --addnfs=173.31.1.254:/test --dir=/test mic0
this step show some warning messages:
[Warning] mic0: Server 173.31.1.254 may not be reachable if the interface is not routed out of the host
5. restart mpss
> systemctl restart mpss
mpss restart fails every time in this step even I tried to uninstall mpss and do all the previously steps all over again,
using > systemctl status mpss.service -l shows:
mpss.service - Intel(R) MPSS control service
Loaded: loaded (/etc/systemd/system/mpss.service; enabled)
Active: failed (Result: exit-code) since Thu 2015-03-05 10:39:43 GMT; 51s ago
Process: 13867 ExecStop=/etc/init.d/mpss stop (code=exited, status=0/SUCCESS)
Process: 13968 ExecStart=/etc/init.d/mpss start (code=exited, status=1/FAILURE)
Main PID: 13218 (code=exited, status=0/SUCCESS)
CGroup: /system.slice/mpss.serviceMar 05 10:39:43 cluster0 mpss[13968]: Starting Intel(R) MPSS: [FAILED]
Mar 05 10:39:43 cluster0 systemd[1]: mpss.service: control process exited, code=exited status=1
Mar 05 10:39:43 cluster0 systemd[1]: Failed to start Intel(R) MPSS control service.
Mar 05 10:39:43 cluster0 systemd[1]: Unit mpss.service entered failed state.
micctrl -s also shows: mic0: boot failed
But after about twenty minutes, mic0 will be back online again and mpss can be restarted. however, when using
>mount in mic0, no mounted entry shows up.
in host /var/mpss/mic0/etc/fstab and mic0 /etc/fstab, both list the mounted entry:
173.31.1.254:/test /test nfs nolock 1 1
try > mount -a in mic0 just hang in there.
># micctrl --config mic0
mic0:
Config Version: 1.1Linux Kernel: /usr/share/mpss/boot/bzImage-knightscorner
Map File: /usr/share/mpss/boot/System.map-knightscorner
BootOnStart: Enabled
Shutdowntimeout: 300 secondsExtraCommandLine: highres=off
PowerManagment: cpufreq_on;corec6_off;pc3_on;pc6_offRoot Device: Dynamic Ram Filesystem /var/mpss/mic0.image.gz from:
Base: CPIO /usr/share/mpss/boot/initramfs-knightscorner.cpio.gz
CommonDir: Directory /var/mpss/common
Micdir: Directory /var/mpss/mic0Network: Static Pair
Hostname: cluster0-mic0
MIC IP: 172.31.1.1
Host IP: 172.31.1.254
Net Bits: 24
NetMask: 255.255.255.0
MtuSize: 64512
MIC MAC: 4c:79:ba:20:04:e4
Host MAC: 4c:79:ba:20:04:e5LDAP: Disabled
NIS: DisabledCgroup:
Memory: DisabledConsole: hvc0
VerboseLogging: Disabled
CrashDump: /var/crash/mic 16GB
Thanks in advance for any suggestions.
QI
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I'm afraid this question was missed somehow but hopefully, the user found the problem - there is a typo in the configuration. The IP address given to the host side of the host/mic0 connection is 172.31.1.254, but when the nfs mount was added to the coprocessor using micctrl, the address was mis-typed as 173.31.1.254. Uninstalling, then reinstalling the MPSS did not resolve this problem because the configuration files are preserved across MPSS uninstalls and reinstalls - which is what you would want if you are installing a new MPSS. To remove erroneous entry, the 'micctrl --remnfs=<mnt_dir>' command was needed.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
