Software Archive
Read-only legacy content
17061 Diskussionen
MPSS 3.5.2 MLNX OFED 2.3.2 Infiniband problems Centos 6.6
Gabriel_D_
Einsteiger
488Aufrufe
I have installed MLNX_OFED_LINUX-2.3-2.0.0 with MPSS 3.5.2 and I'm getting the next error in the output of ibv_devinfo:
Failed to query device propshca_id:    mlx4_0
    node_guid:            xxxx:xxxx:xxxx:xxxx
    sys_image_guid:            xxxx:xxxx:xxxx:xxxx
    vendor_id:            xxxxcx
    vendor_part_id:            4099
    hw_ver:                0x1
    board_id:            XXXXXXXXXXXX
    phys_port_cnt:            1
        port:    1
            state:            PORT_ACTIVE (4)
            max_mtu:        4096 (5)
            active_mtu:        4096 (5)
            sm_lid:            2
            port_lid:        132
            port_lmc:        0x00
            link_layer:        InfiniBand
...and also when I'm accesing to micN, in ifconfig Infiniband Interface does not appear..
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
mic0      Link encap:Ethernet  HWaddr XX:XX:XX:XX:XX:XX
          inet addr:172.31.0.2  Bcast:172.31.0.255  Mask:255.255.255.0
          UP BROADCAST RUNNING  MTU:1500  Metric:1
          RX packets:288 errors:0 dropped:0 overruns:0 frame:0
          TX packets:218 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:36003 (35.1 KiB)  TX bytes:35431 (34.6 KiB)
mic0:ib   Link encap:Ethernet  HWaddr XX:XX:XX:XX:XX:XX
          inet addr:xxxx.xxxx.xxxx.xxxx  Bcast:0.0.0.0  Mask:255.255.255.0
...but, from the host it does... ..I did an external bridging and if I do ping to 172.31.0.2...it works, but obviously something is wrong, because the error mentioned above.
So, what is wrong? I've been trying to install MPSS whit Infiniband but it seems not work. I'm running in Centos 6.6 in a cluster.
1 Antworten
Loc_N_Intel
Mitarbeiter
488Aufrufe
Hi Gabriel,
I take a look at the MPSS 3.5.2 User Guide, section 3.6.1 states that Mellanox* OFED 2.1, 2.2, 2.3-1.0.1 have been tested. You may try Mellanox* OFED 2.3-1.0.1 instead of 2.3.2.0.0 .
Note that the official Linux OS's that MPSS supports are RHEL and SUSE, not Centos. But you can try and see.
Thank you.
Antworten
