Software Archive
Read-only legacy content
17061 Diskussionen
MSVS2013 debugger crash with ps_xe_2013_sp1_update1
David_Eberly
Neuer Beitragender I
2.717Aufrufe
I installed parallel_studio_xe_2013_sp1_update1 that recently shipped (downloaded on 10/2013).  I have MSVS Professional 2012 (Version 11.0.60610.01 Update 3) and MSVS Professional 2013 (Version 12.0.21005.1 REL) installed.  I have an assertion system in my source code that eventually calls __debugbreak().  When this code is executed during a debug run, I get an error dialog:  "The debugger's worker process (msvsmon.exe) unexpectedly exited.  Debugging will be aborted."  I dismiss the dialog and the program abnormally terminates, which it should not (I should get a call stack that led to the __debugbreak call).  I uninstalled all Parallel Studio XE components.  When I run my program again, it works properly when __debugbreak() is called.  I reinstalled Parallel Studio XE, ran the program, and get the aforementioned error dialog.  With PSXE installed, I ran the following simple program:  #include <intrin.h> int main() { __debugbreak(); return 0; }.  MSVS 2013 dies, which Windows traps and sends a report to Microsoft.  In this simple program and the other one I mentioned, if I set a breakpoint at __debugbreak() and run, I reach the breakpoint and can step over the function.  Neither program terminates in this experiment.
Anyone else experience similar problems and know of a work around?
21 Antworten
Bernard
Geschätzter Beitragender I
2.555Aufrufe
Is there any error code associated with the crashing process?
Bernard
2.555Aufrufe
Dave Welcome you on IDZ forum.
David_Eberly
2.555Aufrufe
The output window of MSVS 2013 shows an exit code of -1 (0xffffffff).  This is not something I return because, as mentioned, the program abnormally terminates and I never reach the return in my 'main' code.
Bernard
2.555Aufrufe
This is too generic to be meaningful.You can collect a minidump of failed debug process,as it may not help to solve the problem it may help to understand the culprit of the crash(hopefully).
David_Eberly
2.555Aufrufe
msvsmon.exe is generating a minimdump.  The exception code is 0xC00000FD.  The exception information is "The thread used up its stack."  If it matters, I am running Windows 8.1 (OS Version 6.3.9600).
Inge_H_
Einsteiger
2.555Aufrufe
Perhaps this is related to this Intel Parallel Studio stack overflow that also crashes Visual Studio http://software.intel.com/en-us/forums/topic/487841
Inge_H_
Einsteiger
2.555Aufrufe
I have the same problem with msvsmon.exe crashing and have attached the Application Crash dump files.
Also, here is some lines from NT event manager (translated):
Version=1
EventType=APPCRASH
EventTime=130282703079075967
ReportType=2
Consent=1
UploadTime=130282703080032210
ReportIdentifier=db077b66-4760-11e3-825e-14109fd19d86
IntegratorReportIdentifier=db077b65-4760-11e3-825e-14109fd19d86
NsAppName=msvsmon.exe
Response.type=4
Sig[0].Name=Appnavn <-- "Appname"
Sig[0].Value=msvsmon.exe
Sig[1].Name=Programversjon <-- "Program version"
Sig[1].Value=12.0.21005.1
Sig[2].Name=Tidsstempel for program <-- "Timestamp for program"
Sig[2].Value=524f9c4c
Sig[3].Name=Navn på feilmodul <-- "Error module name"
Sig[3].Value=ntdll.dll
Sig[4].Name=Feilmodulversjon <-- "Error module version"
Sig[4].Value=6.3.9600.16408
Sig[5].Name=Tidsstempel for feilmodul <-- "Timestamp for error module"
Sig[5].Value=523d5305
Sig[6].Name=Unntakskode <-- "Exception code"
Sig[6].Value=c00000fd <--- This means stack overflow
Sig[7].Name=Unntaksforskyvning <-- "Exception Offset"
Sig[7].Value=0000000000052e2e
As far as I can see msvsmon.exe links two Intel libraries that may be the culprit here:
<MATCHING_FILE NAME="CPUSideRDM.dll" SIZE="165816" SIZE_OF_IMAGE="0x2B000" CHECKSUM="0xAEA98B8F" BIN_FILE_VERSION="1.0.8.0" BIN_PRODUCT_VERSION="1.0.8.0" PRODUCT_VERSION="1.0.8.0" FILE_DESCRIPTION="CPUSideRDM" COMPANY_NAME="Intel Corporation" PRODUCT_NAME="Intel(R) Debugger Extension for Intel(R) MIC Architecture" FILE_VERSION="1.0.8.0" ORIGINAL_FILENAME="CPUSideRDM.dll" INTERNAL_NAME="CPUSideRDM.dll" LEGAL_COPYRIGHT="Copyright 2011 - 2013 Intel Corporation All Rights Reserved" VERDATEHI="0x0" VERDATELO="0x0" VERFILEOS="0x4" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x37F49" LINKER_VERSION="0x0" FROM_BIN_FILE_VERSION="1.0.8.0" FROM_BIN_PRODUCT_VERSION="1.0.8.0" UPTO_BIN_FILE_VERSION="1.0.8.0" UPTO_BIN_PRODUCT_VERSION="1.0.8.0" LINK_DATE="09/27/2013 14:13:19" FROM_LINK_DATE="09/27/2013 14:13:19" UPTO_LINK_DATE="09/27/2013 14:13:19" EXPORT_NAME="CPUSideRDM.DLL" VER_LANGUAGE="Engelsk (USA) [0x409]" EXE_WRAPPER="0x0" CRC_CHECKSUM="0x6D530134" />
<MATCHING_FILE NAME="intel-pinadx-bdm-2.12.60355.dll" SIZE="482816" SIZE_OF_IMAGE="0x79000" CHECKSUM="0x77BF6BD2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" LINK_DATE="07/20/2013 19:14:22" FROM_LINK_DATE="07/20/2013 19:14:22" UPTO_LINK_DATE="07/20/2013 19:14:22" EXPORT_NAME="intel-pinadx-bdm-2.12.60355.dll" EXE_WRAPPER="0x0" CRC_CHECKSUM="0x2EDCF2D6" />
Bernard
2.555Aufrufe
It seems that this is the ofending call stack(according to windbg analyze command).You are using Triage dump file which do not contain the full information and overwrites certain values with 0xaaaaaaaa pattern.Please use .dump /ma command to collect full user dump.
RetAddr : Args to Child : Call Site
00000000`00000000 : 00000000`00000030 00000000`00000000 00000004`aac5f740 aaaaaaaa`aaaaaaaa : ntdll!NtGetContextThread+0xa
0:001> r
rax=aaaaaaaaaaaaaaaa rbx=aaaaaaaaaaaaaaaa rcx=aaaaaaaaaaaaaaaa
rdx=0000000000000000 rsi=aaaaaaaaaaaaaaaa rdi=00000004aac5f7a0
rip=00007ffc43f2738a rsp=00000004aac5f6a8 rbp=aaaaaaaaaaaaaaaa
r8=0000000000000080 r9=0000000000000000 r10=aaaaaaaaaaaaaaaa
r11=aaaaaaaaaaaaaaaa r12=aaaaaaaaaaaaaaaa r13=aaaaaaaaaaaaaaaa
r14=aaaaaaaaaaaaaaaa r15=aaaaaaaaaaaaaaaa
iopl=0 nv up ei pl zr na po nc
cs=0033 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00000246
ntdll!NtGetContextThread+0xa:
00007ffc`43f2738a c3 ret
Bernard
2.555Aufrufe
@Inge
your second crash dump captures more content(recuring functions call) which could point to recursive function calls as a culprit of stack overflow.
Here is the call stack snippet
0:042> ~42kb 0xffff
ChildEBP RetAddr Args to Child
1f5994d8 779664ee aaaaaaaa 00000000 aaaaaaaa KERNELBASE!RaiseException+0x48
1f59974c 77990805 1f993ae0 aaaaaaaa aaaaaaaa KERNELBASE!OutputDebugStringA+0x55
1f59976c aaaaaaaa 1f5997a4 52560161 aaaaaaaa KERNELBASE!OutputDebugStringW+0x52
WARNING: Frame IP not in any known module. Following frames may be wrong.
1f599774 52560161 aaaaaaaa aaaaaaaa 20c34958 0xaaaaaaaa
1f5997a4 52556c8c 1f599d88 aaaaaaaa 00000000 CPUSideRDM+0x10161
1f599db0 52ece9f5 07a50d70 20c34958 20c44e00 CPUSideRDM+0x6c8c
1f599e38 52556eb0 20c34958 aaaaaaaa 00000000 VSDebugEng+0xae9f5
1f59a444 52ece9f5 07a50d70 20c34958 20c44d90 CPUSideRDM+0x6eb0
1f59a4cc 52556eb0 20c34958 aaaaaaaa 00000000 VSDebugEng+0xae9f5
1f59aad8 52ece9f5 07a50d70 20c34958 20c45180 CPUSideRDM+0x6eb0
1f59ab60 52556eb0 20c34958 aaaaaaaa 00000000 VSDebugEng+0xae9f5
1f59b16c 52ece9f5 07a50d70 20c34958 20c44d20 CPUSideRDM+0x6eb0
1f59b1f4 52556eb0 20c34958 aaaaaaaa 00000000 VSDebugEng+0xae9f5
1f59b800 52ece9f5 07a50d70 20c34958 20c44cb0 CPUSideRDM+0x6eb0
1f59b888 52556eb0 20c34958 aaaaaaaa 00000000 VSDebugEng+0xae9f5
1f59be94 52ece9f5 07a50d70 20c34958 20c44c40 CPUSideRDM+0x6eb0
1f59bf1c 52556eb0 20c34958 aaaaaaaa 00000000 VSDebugEng+0xae9f5
1f59c528 52ece9f5 07a50d70 20c34958 20c44bd0 CPUSideRDM+0x6eb0
1f59c5b0 52556eb0 20c34958 aaaaaaaa 00000000 VSDebugEng+0xae9f5
1f59cbbc 52ece9f5 07a50d70 20c34958 20c456c0 CPUSideRDM+0x6eb0
1f59cc44 52556eb0 20c34958 aaaaaaaa 00000000 VSDebugEng+0xae9f5
1f59d250 52ece9f5 07a50d70 20c34958 20c450a0 CPUSideRDM+0x6eb0
1f59d2d8 52556eb0 20c34958 aaaaaaaa 00000000 VSDebugEng+0xae9f5
1f59d8e4 52ece9f5 07a50d70 20c34958 20c45960 CPUSideRDM+0x6eb0
1f59d96c 52556eb0 20c34958 aaaaaaaa 00000000 VSDebugEng+0xae9f5
1f59df78 52ece9f5 07a50d70 20c34958 20c458f0 CPUSideRDM+0x6eb0
1f59e000 52556eb0 20c34958 aaaaaaaa 00000000 VSDebugEng+0xae9f5
1f59e60c 52ece9f5 07a50d70 20c34958 20c45880 CPUSideRDM+0x6eb0
Inge_H_
Einsteiger
2.555Aufrufe
Sorry, but I can't seem to generate a better memdump since it won't allow me to attach the debugger. My code works fine until I set a breakpoint, then the debugger crashes. I read online that the forums were the right place to post bugs in the Intel products, but there does not seem to be much feedback from Intel on this and iliyapolak is not from Intel afaik.
Bernard
2.555Aufrufe
It seems that crash originated in VSDebugEng process and for now it is unknown how the Parallel Studio can be responsible for that.
Regarding the crash try to post on Compiler forum.No I am not from Intel,but I have some knowledge related to debugging and I am trying to help here on IDZ.
David_Eberly
2.555Aufrufe
You have been helpful by asking us to provide specific information, thank you.  Others have reported similar problems.  Although the adverse interaction between Parallel Studio and MSVS 2013 is not clear to us users, I hope that the problem is clear to the Intel folks and that they can provide a fix shortly.  It is difficult for me to develop normally when each time an assertion is triggered, MSVS 2013 crashes when I press the "Retry" button.  Of course I can uninstall Parallel Studio to avoid the problem, but this is an important tool in my development environment.  Looking forward to the fix.
Bernard
2.555Aufrufe
>>>Sorry, but I can't seem to generate a better memdump since it won't allow me to attach the debugger.>>>
You can run VS from within the windbg and set break on exception to enable.You can even debug a debugger.
Poeter__Manuel
Einsteiger
2.555Aufrufe
I was having the same problem and nailed it down to the Intel Debugger Extension CPUSideRDM.dll
I debugged the msvsmon.exe and got the following callstack:
[plain]
00000031`6c54dcb8 00007ffa`dc58797b VSDebugEng!dispatcher::Exceptions::DkmExceptionInformation::OnDebugMonitorException
00000031`6c54dcc0 00007ffa`d0a6d317 CPUSideRDM!DllGetClassObject+0x67bb
00000031`6c54e5d0 00007ffa`dc58797b VSDebugEng!dispatcher::Exceptions::DkmExceptionInformation::OnDebugMonitorException+0x113
00000031`6c54e670 00007ffa`d0a6d317 CPUSideRDM!DllGetClassObject+0x67bb
00000031`6c54ef80 00007ffa`dc58797b VSDebugEng!dispatcher::Exceptions::DkmExceptionInformation::OnDebugMonitorException+0x113
00000031`6c54f020 00007ffa`d0a6d317 CPUSideRDM!DllGetClassObject+0x67bb
00000031`6c54f930 00007ffa`ca2d7057 VSDebugEng!dispatcher::Exceptions::DkmExceptionInformation::OnDebugMonitorException+0x113
00000031`6c54f9d0 00007ffa`ca2d6904 vsdebugeng_impl!Win32BDM::CBaseDebugMonitor::RaiseExceptionEvent+0x11f
00000031`6c54fa70 00007ffa`ca2d676b vsdebugeng_impl!Win32BDM::CBaseDebugMonitor::HandleExceptionDebugEventImpl+0x16c
00000031`6c54fb00 00007ffa`ca2d6261 vsdebugeng_impl!Win32BDM::CBaseDebugMonitor::HandleExceptionDebugEvent+0xd7
00000031`6c54fb70 00007ffa`ca2d5d89 vsdebugeng_impl!Win32BDM::CBaseDebugMonitor::HandleDebugEvent+0x1c5
00000031`6c54fbe0 00007ffa`e7721611 vsdebugeng_impl!Win32BDM::CBaseDebugMonitor::DebugLoop+0x149
00000031`6c54fda0 00007ffa`e9ac64ad KERNEL32!BaseThreadInitThunk+0xd
00000031`6c54fdd0 00000000`00000000 ntdll!RtlUserThreadStart+0x1d
[/plain]
The last few frames show the recursion that eventually leads to the stack overflow. I have created a full minidump from the debug session that I can provide (~74MB).
The issue can simply be fixed by uninstalling the Intel Debugger Extension (as long as you don't need it).
Bernard
2.555Aufrufe
Hi can you upload your full minidump?
It seems that your minidump has properly resolved function names.
Inge_H_
Einsteiger
2.555Aufrufe
Microsoft support is blaming Intel for this one:
As Karthik pointed out below, this is not a Visual Studio issue. This is caused by CPUSideRDM.dll. You should talk to Intel Parallel Studio XE 2013 team about it. They might not be aware of this bug!
Maria (Visual Studio Debugger)
http://connect.microsoft.com/VisualStudio/feedback/details/807629/msvsmon-exe-crashes-when-starting-debugging
The cause of the problem is not with Visual Studio, but with CPUSideRDM.dll, which is part of Intel C++ Studio XE 2013 - you might want to contact them about this!
https://connect.microsoft.com/VisualStudio/feedback/details/807509/throw-std-runtime-error-crashes-visual-studio-2013-ide
Bernard
2.555Aufrufe
You know they are partially right because the recursion is caused by  CPUSideRDM.dll. But when you look at the function call  CPUSideRDM.dll is calling DllGetClassObject and the failure can be due to misbehaving Windows code.I suppose that one of the parameters passed to DllGetClassObject could be wrong and thus triggers the recursion.
Alexey_I_
Einsteiger
2.555Aufrufe
I'm the reporter of the MS bug
Unbale to upload my minidump. There is callstack of it.
     ntdll.dll!00000000776e863b()
     ntdll.dll!00000000776e57b4()
     KERNELBASE.dll!000007fefd71ab85()
     ntdll.dll!00000000776f9d2d()
     ntdll.dll!00000000776e91cf()
     ntdll.dll!00000000776e97c8()
     KERNELBASE.dll!000007fefd70940d()
     KERNELBASE.dll!000007fefd71aa0d()
     KERNELBASE.dll!000007fefd73f5a6()
     CPUSideRDM.dll!000007fef9fb76f6()
     VSDebugEng.dll!000007fed9e3d317()
     CPUSideRDM.dll!000007fef9fb797b()
     vsdebugeng.impl.dll!000007feda2ffe72()
     vsdebugeng.impl.dll!000007feda2ff73c()
     vsdebugeng.impl.dll!000007feda2f80ce()
     vsdebugeng.impl.dll!000007feda2f6bfe()
     vsdebugeng.impl.dll!000007feda317057()
     vsdebugeng.impl.dll!000007feda316904()
     vsdebugeng.impl.dll!000007feda31676b()
     vsdebugeng.impl.dll!000007feda316261()
     vsdebugeng.impl.dll!000007feda315d89()
     kernel32.dll!00000000775c652d()
     ntdll.dll!00000000776fc541()
Alexey_I_
Einsteiger
2.555Aufrufe
deleted
Bernard
2.407Aufrufe
If somone could upload process full minidump and not triage dump because crucial info like function parameters are overwritten with 0xaaaaaaaa string thus rendering impossible investigate full callstack.
Antworten
