Software Archive
Read-only legacy content
Mapping Audio to I2c
Darren_S_1
I have an Edison with a DFRobot board that has i2C on the board.  I have connected an Adafruit Stereo 2.8W Class D Audio Amplifier - I2C Control AGC - TPA2016.  I can see the device on i2cdetect -l 6 address range 0x03-0x77.  I would like to map audio playback to this device rather than using either BT or USB.  I am on Yocto 3.10.17-poky-edison+
I would hope that I could edit a config file to tell the system that playback should go through i2c.  Any help would be appreciated.
Harold_G_Intel
Hi Darren,
The Intel(R) Edison module is supported in communities.  You may want to repost this here:  https://communities.intel.com/community/tech/edison
Regards, Hal
Intel(R) Developer Zone Support
http://software.intel.com
*Other names and brands may be claimed as the property of other
