Software Archive
Read-only legacy content
17060 Discussions
Maps on Windows Phone 8.1
Ilker_O_
I use Intel XDK's geolocation sample.I set all build settings and api key then deploy my phone.But when index.html run app crashed.
How can I set map?
Elroy_A_Intel
This seems to be a bug with Windows Phone and/or Google Maps. I recommend making sure you are using the latest version of google maps API script.
Consider trying some of these samples provided directly by Google Maps as well at https://developers.google.com/maps/documentation/javascript/examples/#basics.
Also, make sure you have the appropriate URLs if you are not using * (which allows your app to access all URLs) under the Project Tab > Build Settings > Whitelist.
Ilker_O_
Hi Elroy
My code is
<html>
    <head>
        <script type="text/javascript" src="cordova.js"></script>
        <script type="text/javascript" src="scripts/platformOverrides.js"></script>
        <script type="text/javascript" src="http://maps.google.com/maps/api/js?v=3.17&sensor=false"></script>
        <script>
            function initialize() {
              var mapProp = {
                center:new google.maps.LatLng(51.508742,-0.120850),
                zoom:5,
                mapTypeId:google.maps.MapTypeId.ROADMAP
              var map=new google.maps.Map(document.getElementById("googleMap"), mapProp);
        </script>
    </head>
    <body>
        <div id="googleMap" style="width:500px;height:380px;"></div>
    </body>
</html>
I added whitelist
<access origin="*.google.com" />
  <access origin="*.googleapis.com" />
  <access origin="*.gstatic.com" />
  <access origin="*.googleusercontent.com" />
  <access origin="google.com" subdomains="true"/>
  <access origin="googleapis.com" subdomains="true"/>
  <access origin="gstatic.com" subdomains="true"/>
  <access origin="googleusercontent.com" subdomains="true"/>
  <access origin="http://maps.google.com" subdomains="true"/>
  <access origin="http://*.google.com" subdomains="true"/>
  <access origin="*" />
When run the app,the exception is Can’t load <http://maps.google.com/maps/api/js?v=3.17&sensor=false>.
can’t load remote web content in the local context.
PaulF_IntelCorp
Try adding this script to your app, see the readme for details > https://github.com/xmnboy/xdk-win8x-compat.js <
Ilker_O_
Hi Paul,
I fixed my problem with use this sample.
http://www.creepyed.com/2012/11/how-to-use-the-google-maps-api-on-windows-8/
I don't know this is correct way but map problem was solved.
I change iframe src like this
ondeviceready(){
var lat = getDataInSession('lat');
var long = getDataInSession('long');
var url = ms-appx-web:///www/map.html?lat=lat&long=long
$('#Map').attr(src,url);
and then parse the url in the map.js and set lat and long values.
Thank you for your helps.
