Software Archive
Read-only legacy content
17060 Discussions
Memory copy using Intel Quickdata technology
Vasudev_J_
I am doing the experimentation on improving the memory-to-memory copy performance (NIC to memory also, but secondary). I have seen that Intel I/OAT provides the Quickdata technology feature to offload the copies using DMA engine.
1. I haven't seen many i/oat related discussions in past few years, is it replaced with other more improved technology in new chipsets?
2. I need the Quickdata technology feature, how can I detect that my processor has Quickdata technology? In lspci, it is not showing anything related to Intel Quickdata Technology.
3. Which latest system/server should I buy to get the Quickdata Technology feature? If you can tell about NIC to memory copy (similar to TCP/IP offloads in i/oat), that will be very helpful.
Many thanks in advance.
Harold_G_Intel
You may want to try posting this in the server and/or chipset forums.
https://communities.intel.com/community/tech/chipsets
https://communities.intel.com/community/tech/servers
Regards, Hal G
Intel(R) Developer Zone Support
http://software.intel.com
*Other names and brands may be claimed as the property of others.
