I have a Slurm as queue manager for my cluster, where the Xeon Phi is connected. I wish to run Xeon Phi application with Slurm commands from the login host. Is it possible to compile SLURM for intel Xeon PHI?
If not is possible to compile Slurm for Xeon Phi. Can I make ssh passwordless between xeon phi host and xeon phi card permanent and resistant to xenon phi card reboots?
Thanks in advance and regards!
Did you have the newer versions of SLURM installed ? It has Xeon Phi (Intel MIC) support (http://slurm.schedmd.com/news.html). However, I don't think it can run Offload mode but use Phi as an independent node.
-- Wendy
Well, you do not need slurmd on the Phi-side. It's possible to cross compile it but I've heard that it still needs some "diet".
On the MPSS user manual one can find ways how to establish passwordless ssh-connection to the Phi's with ssh-keys. We mount Lustre to Phi's, so users will have same $HOME and .ssh/authrorized_keys on the Phi side. What I've found is that micctrl --useradd/del does not work from prolog/epilog scripts, so one has to do user management with shell scripts (or maybe with LDAP).
With mpirun-mic wrapper one can run jobs on the host, mics or mixed mode, see:
https://github.com/SchedMD/slurm/blob/master/contribs/mic/mpirun-mic
https://confluence.csc.fi/display/HPCproto/HPC+Prototypes#HPCPrototypes-XeonPhiDevelopment
