Software Archive
Read-only legacy content
17061 Discussions
Missing external - __beginthreadex
isn-removed200637
I have recently installed 6.6Pro and have started playing with one of my old QuickWin projects. I opened the workspace after letting Fortran convert it from the previous format and then tried to rebuild the project.
The link step failed with unsatisfied external as shown below, where I have listed the project library settings.
Linking...
DFQWIN.LIB(qwkentry.obj) : error LNK2001: unresolved external symbol __beginthreadex
DFQWIN.LIB(qwgwnd.obj) : error LNK2001: unresolved external symbol __beginthreadex
Release/SPLINEIGS.exe : fatal error LNK1120: 1 unresolved externals
Error executing link.exe.
SPLINEIGS.exe - 3 error(s), 0 warning(s)
LINK STEP LIBRARIES:
kernel32.lib DFQWIN.LIB DFQW_MDI.LIB COMDLG32.LIB
IGNORE LIBRARIES:
DFCONSOL.LIB
I tried a modification to the link libraries as shown below, but got a different set of unsatisfied externals.
Linking...
dfor.lib(for_m_qqs.obj) : error LNK2001: unresolved external symbol _errno
dfor.lib(for_m_diskdir.obj) : error LNK2001: unresolved external symbol _errno
dfor.lib(for_portlib.obj) : error LNK2001: unresolved external symbol _errno
dfor.lib(for_init.obj) : error LNK2001: unresolved external symbol __pxcptinfoptrs
Release/SPLINEIGS.exe : fatal error LNK1120: 2 unresolved externals
SPLINEIGS.exe - 5 error(s), 0 warning(s)
kernel32.lib LIBCMT.LIB DFQWIN.LIB DFQW_MDI.LIB COMDLG32.LIB
IGNORE LIBRARIES:
LIBC.LIB,DFCONSOL.LIB
Can Anyone advise on a library search/ignore set that should work and
satisfy the externals without duplicating symbols? (I find that using LIBCMT.LIB and LIBC.LIB gives me duplicates of other object files, so the link step still fails)
Steven_L_Intel1
You shouldn't have to play with explicitly specifying libraries and ignore-libraries.
How about trying this: create a new QuickWin project, add your sources, and build. What happens? If you still have problems, send a ZIP archive of your workspace to vf-support@compaq.com
Steve
isn-removed200637
Thanks for your advice, but I think I found the solution to the problem. I looked at Project..Settings...Fortran tab..Category 'Libraries' and found that 'Single threaded' was selected into the Run-time-libraries box. I changed this to multithreaded and went back to the first library search list that was carried over with the project when it was converted
to be compatible with the latest vrsion of Fortran 6.6 pro.:
IGNORE LIBRARIES:
DFCONSOL.LIB
The executable built ok with no errors.
Tony Richards
Steven_L_Intel1
How did it get set that way in the first place? Do you have library subprojects?
Steve
isn-removed200637
As I said, I upgraded to 6.6 Pro from 5.0D and opened the old project. The work-space format was recognised as an old one and Visual Studio offered to convert it, which I accepted and the project opened ok. I can only suppose that it was during this stage that the multithread settings were lost.
