Software Archive
Read-only legacy content
17060 Discussions
Mobile SDK: Events
atkulp
The more I try to get done, the more frustrated I become! I must be doing something wrong. I'm using the C# version (IntelMobileCLR.dll) in a Windows Forms project (on VMWare Workstation 5.5, Windows Server 2003/SP1). I'm using almost identical code to the DelegateEventSample, yet no event ever fires. I know that the underlying mechanism works since the C# Information Viewer (SDK tool) and the sample C# project (DelegateEventSample) both respond to events properly. My code is as follows:
class MainForm : Form
CapabilityClass myCapabilities = new CapabilityClass();
ConnectivityInstance myConnectivity;
public MainForm()
myConnectivity = (ConnectivityInstance)
myCapabilities.GetInstance("Connectivity");
DelegateObserver.ObserverNotifyDelegate del = new
DelegateObserver.ObserverNotifyDelegate(
ConnectedEventHandler);
Observer connectedChangeObsvr = new DelegateObserver(del);
myConnectivity.Connect.AddObserver(connectedChangeObsvr);
myConnectivity.Disconnect.AddObserver(connectedChangeObsvr);
private void ConnectedEventHandler(Event e)
Is there any limitation from Windows Forms? To test it, I enable and disable the adapter from VMWare. As I mentioned, it fires the event in the sample and the included SDK tool -- just not in my code.
Your help is *very* much appreciated!!
Intel_Software_Netw1
We are following up with engineering and will let you know how they respond.
Lexi S.
IntelSoftware NetworkSupport
http://www.intel.com/software
Contact us
Yuqi_L_Intel
Are you using STA in the Windows Forms? If so switching to MTA should be ok.
[STAThread] [MTAThread]
static voidMain()
Application.Run(new Form1());
Currently, IMPSDK is only supporting Multi-Thread apartment model to receive event notification
atkulp
Hooray! Another one to clear as fixed! My mistake. This was in the SDK documentation, I just missed it, being focused on the actual objects, methods, and properties. Thanks for responding!
