Software Archive
Read-only legacy content
17060 Discussions
Model Specific Error Code for MCE occurring on 06_3Ch DisplayFamily_DisplayModel
caliniaru
Hi, I got a BSOD due to a Machine Check Exception. The CPU is an i7 4790S. 1: kd> !cpuinfo 0 CP F/M/S Manufacturer MHz PRCB Signature MSR 8B Signature Features 0 6,60,3 GenuineIntel 3192 0000001700000000 21193ffe Cached Update Signature 0000001700000000 Initial Update Signature 0000001700000000 1: kd> .bugcheck Bugcheck code 00000124 Arguments 00000000`00000000 fffffa80`1c297028 00000000`fe000000 00000000`00800400 1: kd> !errrec fffffa80`1c297028 =============================================================================== Common Platform Error Record @ fffffa801c297028 ------------------------------------------------------------------------------- Record Id : 01d0fa0fb97d2405 Severity : Fatal (1) Length : 928 Creator : Microsoft Notify Type : Machine Check Exception Timestamp : 9/29/2015 0:21:24 Flags : 0x00000000 =============================================================================== Section 0 : Processor Generic ------------------------------------------------------------------------------- Descriptor @ fffffa801c2970a8 Section @ fffffa801c297180 Offset : 344 Length : 192 Flags : 0x00000001 Primary Severity : Fatal Proc. Type : x86/x64 Instr. Set : x64 Error Type : Micro-Architectural Error Flags : 0x00 CPU Version : 0x00000000000306c3 Processor ID : 0x0000000000000001 =============================================================================== Section 1 : x86/x64 Processor Specific ------------------------------------------------------------------------------- Descriptor @ fffffa801c2970f0 Section @ fffffa801c297240 Offset : 536 Length : 128 Flags : 0x00000000 Severity : Fatal Local APIC Id : 0x0000000000000001 CPU Id : c3 06 03 00 00 08 10 01 - ff fb fa 7f ff fb eb bf 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 Proc. Info 0 @ fffffa801c297240 =============================================================================== Section 2 : x86/x64 MCA ------------------------------------------------------------------------------- Descriptor @ fffffa801c297138 Section @ fffffa801c2972c0 Offset : 664 Length : 264 Flags : 0x00000000 Severity : Fatal Error : Internal timer (Proc 1 Bank 4) Status : 0xfe00000000800400 Address : 0x000007fefcb36ddb Misc. : 0x000007fefcb36ddb This 2nd section is most likely the culprit. I have looked for IA32_MCi_STATUS[31:16] = 0080 to figure out what kind of Internal Timer Error occurs, but for this 06_3Ch Family/Model I could not find a Model Specific Error Code. Can you tell me if there are other models that are compatible with this Haswell Microarchitecture? The MCA_SECTION contains the following values: 1: kd> dd fffffa801c2972c0 L0n66 fffffa80`1c2972c0 00000001 00000001 c635d67f 01d0fa4c fffffa80`1c2972d0 00000001 00000005 00000000 00000000 fffffa80`1c2972e0 00000000 00000004 00800400 fe000000 fffffa80`1c2972f0 fcb36ddb 000007fe fcb36ddb 000007fe fffffa80`1c297300 00000000 00000000 00000000 00000000 fffffa80`1c297310 00000000 00000000 00000000 00000000 fffffa80`1c297320 00000000 00000000 00000000 00000000 fffffa80`1c297330 00000000 00000000 00000000 00000000 fffffa80`1c297340 00000000 00000000 00000000 00000000 fffffa80`1c297350 00000000 00000000 00000000 00000000 fffffa80`1c297360 00000000 00000000 00000000 00000000 fffffa80`1c297370 00000000 00000000 00000000 00000000 fffffa80`1c297380 00000000 00000000 00000000 00000000 fffffa80`1c297390 00000000 00000000 00000000 00000000 fffffa80`1c2973a0 00000000 00000000 00000000 00000000 fffffa80`1c2973b0 00000000 00000000 00000000 00000000 fffffa80`1c2973c0 00000000 00000000 And this is how it is laid down by the compiler: typedef union _MCG_STATUS { struct { ULONG RestartIpValid:1; ULONG ErrorIpValid:1; ULONG MachineCheckInProgress:1; ULONG Reserved1:29; ULONG Reserved2; } DUMMYSTRUCTNAME; ULONGLONG QuadPart; } MCG_STATUS, *PMCG_STATUS; typedef union _MCI_STATUS { struct { USHORT McaErrorCode; USHORT ModelErrorCode; ULONG OtherInformation : 23; ULONG ActionRequired : 1; ULONG Signalling : 1; ULONG ContextCorrupt : 1; ULONG AddressValid : 1; ULONG MiscValid : 1; ULONG ErrorEnabled : 1; ULONG UncorrectedError : 1; ULONG StatusOverFlow : 1; ULONG Valid : 1; } DUMMYSTRUCTNAME; ULONG64 QuadPart; } MCI_STATUS, *PMCI_STATUS; typedef enum _WHEA_CPU_VENDOR { WheaCpuVendorOther = 0, WheaCpuVendorIntel, WheaCpuVendorAmd } WHEA_CPU_VENDOR, *PWHEA_CPU_VENDOR; #define WHEA_XPF_MCA_EXTREG_MAX_COUNT 24 #define WHEA_XPF_MCA_SECTION_VERSION 1 typedef struct _WHEA_XPF_MCA_SECTION { ULONG VersionNumber; WHEA_CPU_VENDOR CpuVendor; LARGE_INTEGER Timestamp; ULONG ProcessorNumber; MCG_STATUS GlobalStatus; ULONGLONG InstructionPointer; ULONG BankNumber; MCI_STATUS Status; ULONGLONG Address; ULONGLONG Misc; ULONG ExtendedRegisterCount; ULONG Reserved2; ULONGLONG ExtendedRegisters[WHEA_XPF_MCA_EXTREG_MAX_COUNT]; } WHEA_XPF_MCA_SECTION, *PWHEA_XPF_MCA_SECTION; Regards, Calin
Harold_G_Intel
Hi Calin,
Support for processors is in communities.  You may want to repost here: https://communities.intel.com/community/tech/processors
Regards, Hal
Intel(R) Developer Zone Support
http://software.intel.com
*Other names and brands may be claimed as the property of others.
